Question about Dell 1703FPs 17" TFT LCD Flat Panel Monitor
Monitor usb i have owned a dell 1703fp monitor..this comes with 4 usb ports..but the monitor cant detect any devices when plugged into it..does there is a need for any cables or drivers..?
  • Anonymous Feb 21, 2008
    I have a similar problem. I hae a LG Flatiron monitor with USB ports. Over time, each of the ports has stopped working. Is there any fix?
    Novelist:
  • 139 Answers
There should be a USB cable from one of the usb ports on your computer to a small square (upstream) USB port on the back of your monitor. This will activate the four (downstream) usb ports on your monitor.
Good luck...and I hope this is helpful!!
Posted on Feb 01, 2008
Usb ports do not work
I have a 24" Dell monitor with built-in USB and SD sockets. Sometimes I have had problems with these not being responsive. This usually comes down to electrical connection.
You should do these in order, also testing for USB port availability at each step .
#1 is the monitor powered up? (USB is active only when monitor is switched on with power button on front of bezel)
#2 check that the USB cable at both ends is plugged in! (you need electrical connectivity)
#3 check that the USB port on the PC can see another device like a memory stick
#4 check your PC's software (drivers must be loaded and the USB port recognized)
Sep 25, 2012 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
My dell monitor usb ports don't work anyone how to fix it?
Please check if the monitor's usb port is connected to the tower, the monitor only acts like a USB hub / junction. If it is connected then disconnect it from the existing USB port and connect it to a different USB port. Please refer to the monitor manual link given below
http://support.dell.com/support/edocs/monitors/e172fp/QSE172FP.pdf
Thank you for contacting Fixya.
Jan 03, 2011 | Dell E172FP 17" LCD Flat Panel Monitor
Front panel connector J16 dell dimension 2350
Visit http://support.dell.com select your product and download user manual and maintenance manual. It may solve your problem.
Jul 15, 2009 | Computers & Internet
Dell 1703FP monitor issue
reduce the hardware acceleration on it. I resolved it by reducing acceleration and changing my screen size. It works. I wanted higher resolution but it doesn't seem to be possible for some reason.
Good luck.
Mar 01, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Screeen comes on --then goes blank
Your inverter circuit is faulty. This controls the lights inside the screen so you can see what is happening on the LCD panel itself.
If you shine a torch into the LCD from the top at an angle you will still see the images on the screen. But with no light inside to project it outwards, it's dark.
A local TV repair shop should be able to do the reprair fairly cheap, but it's best to make a few phone calls and check they will work on an LCD monitor firstly, and secondly a rough quote.
This is a very common fault with LCD monitors.
Hope that helps =)
Apr 15, 2008 | Dell UltraSharp 1703FP 17" Flat Panel LCD...
Side USB ports
You need to connect a USB cable from your PC to the USB port under the monitor.
It is a standard usb cable used by printers with a flat plug on one end and a squareish plug on the other.
You should also have 2 more usb ports under the screen as well. There are normally 4 on Dell screens. 2 side, 2 under, and the one square plug to connect to the PC.
Feb 20, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell 1703FPs 17" TFT LCD Flat Panel Monitor Logo
388 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
