Some relays must have got stuck open. Check the following schematic. You should check the Main relay, RY14 and RY15 for lamps and relay RY6 for the fan.
http://www.microwavedisplay.com/advantium_sca1000_sca1001_sm.pdf
For your own safety, always make sure you are working safe. Microwave units can be very deadly. Consult an expert if in doubt.
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
