Question about Dryers
Maytag MDG3000AWW drum moving slowly
Maytag Neptune MDG3000AWW
drum moves very slowly when on = clothes not drying
1) I tried removing some of the clothes thinking maybe the load was too heavy; did not solve
2) I opened up the exhaust hole in the back to see the motor wheels spinning, but the belt not "catching"...
Do I need to replace the belt? Or is the drum gummed up somehow and not spinning freely enough? How can I tell?
Thanks
JK
  • jkrump Feb 02, 2008
    I took the belt off to see if the drum would spin freely...it was very tough to spin it. So I disassembled everything to check for problems. I ended up lubricating the two wheels that the drum sets on and when I reassembled everything, the belt was very loose and has way too much slack in it. I weaved it around the motor pulley and the tenioner pulley but it's still too slack...what the heck?
    Once I get the belt back on I can test the dryer again.
  • 55 Answers
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Posted on Feb 01, 2008
  • peter phillips Feb 02, 2008
    If the idler puller (tensioner pulley) is correctly positioned, and the belt path is correct, perhaps the belt is stretched and needs to be replaced. Check to see whether the drum is properly positioned in both the front and back panels of the dryer. If the drum is hard to turn, it may be improperly postioned, which could cause the belt to slip even if belt is good and path is correct.
Neptune dryer not starting
Yes, I recommend you type in "Sears Parts Direct" to your computer search engine.
Put in your model number in the box, and you will see schematics that will answer your questions.
God bless your efforts.
Feb 26, 2016 | Maytag Dryers
It takes hours to dry the clothes. The dial moves
sounds like a bad timer. if it sticks every time replace they are expensive
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will heat and does dry some but when it moves to the less dry the dial does not move and the dryer does not heat
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Oct 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDG3000AWW Hard starting
your motor bearings or idler tensioner bearings are going dry and need repl
Aug 03, 2009 | Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer takes a long time to dry clothes
your timer is the problem if its not moving
which can be expensive
60-80.00 dollars Dryers are cheap enough to buy a good used one
Jun 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
My maytag neptune gas dryer model #MDG3000AWW When I push the start button on my maytag neptune dryer it sounds like it wants to start but doesn't and then it gets this smell like something is burning?...
It sounds like the drum bearings are seizing up preventing the drum from rolling easily, and when the motor runs, it can't pull the drum belt around the drum that won't turn, so starts squealing and burning the belt.
You need to lubricate/replace the drum bearings, and replace the belt.
Jan 29, 2009 | Dryers
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
513 people viewed this question
Top Dryers Experts
Marvin
Marvin
