My rca wont show up under - Audio Players & Recorders
My rca wont show up under My computer unyil after i take it out and than it goes away when i put it back on so how do i format it?
  • 1 more comment
  • mitch bade69 Feb 04, 2008
    but when i put my mp3 in the usb connection it doesnt show up under "my computer" why is this so?
  • mitch bade69 Feb 11, 2008
    no i'm using media player does it matter?
  • mitch bade69 Feb 18, 2008
    well i have i tunes but when i put it in nothing comes up under i tunes like it doesnt recognize the device
    Sergeant:
    Champion:
  • 322 Answers
Ok plug it in to computer look for driver g then right click then format
Posted on Feb 01, 2008
  • 1 more comment
  • robert smith
    robert smith Feb 05, 2008
    to be honest unless you can get it up on your computer there no outher way of formating it ? , ? are you using itunes ?
  • robert smith
    robert smith Feb 12, 2008
    well id try using itunes as this is a far better program and does all the con verting for you if you happen to get it up on your computer ? go to my computer look for drive G then right click then format it ?
  • robert smith
    robert smith Feb 18, 2008
    well the reason it whont show up on your computer is that most add ons need 2.0 and the internal usb only give 1.0 so i would invest in a hub carrier with it own power sorce and you won,t waste your monet as it can be used for any divice just go to any computer shop and exsplain what you want and they will help you then you should be ok
My Phone Screen Wont Turn On, Even When I Put It On The Charger
Hi take off your memory card and format it 3times, by the way you should do same format for your cellphone. It is a software problem.cheers
Nov 25, 2013 | ZTE Score
I have a DMtech LCD model LV19XTM - the power adapter shows a green light unyil it is plugged into the back of the TV then the light goes off and no power is getting to the TV - is this an adaptor problem...
is this the original power adapter or a new one. If it's a new or different power adapter, it could be the plug configuration on the new power adapter is different, as i had the same problem, but was able to fix it
Oct 19, 2010 | Televison & Video
Dont have the software to put songs on my player
Can you see it your player under My Computer?
I'm also assuming that you have a computer USB cable?
If so, in My Computer right click player, EXPLORE, find the MUSIC folder. Sometimes the manufacturers hide it under a bogus file name, just open each folder, looking inside each until you find a folder named MUSIC.
All your music already has to be in the mp3 format, COPY it from that location (hard drive, CD, flash drive), then PASTE it into the music folder on your player.
Disconnect from the computer and check out your songs, enjoy.
Dec 01, 2009 | RCA TH1611 MP3 Player
The RCA Lyra 1090a says bad or missing lyrasys
What i do is i never put songs in my internal memory...this way you never have to worry about formating the internal memory....so i have several exteral card i use say one for country or rock and its so easy to format a exteral card just place it in ur card reader if ur using a laptop them go to my computer right click on ur card that youll find then youll notice on the list theres format so its so easy...im sure its asking you to format ur drive because you must have a few corrupted files....best of all when adding music just pull ur external card out place it in a reader fill ur card with music then insert it back in ur device...this way ur getting away with using any firmware....by the way take any disc that came with ur Lyra and chuck it in the garbage that 90 percent of all ur problems
Nov 25, 2009 | RCA Lyra RD1090 MP3 Player
Need to reinstall data on RCA Opal M4208GR-B
I did the same thing and reformatted mine too! If you go to www.rcaaudiovideo.com and put in your model number M4208GR and click on the update for the firmware update again then it will put everything back on the MP3 player. I know it sounds nuts but it worked for me and it wont do anymore harm then you have already done ;) Give it a try. Hope it works for you like it did me!
Feb 03, 2009 | RCA M4208 MP3 Player
Help Please!
Try removing the battery and connecting it to the computer.
If it shows up on the Computer, format it.
To format in My Computer>Device Name (Lyra)>Right Click and select format.
This will erase everything on the device and allow you to start over.
Best of Luck.
Oct 14, 2007 | RCA Lyra TH1012 MP3 Player
Error??
boot error format unit
Oct 04, 2007 | RCA OPAL M4001 MP3 Player
HELP PLEASE
Take the battery out and put it back in after a few seconds, turn it on again and pray. If the same happens, plug it in with USB, take all your music onto your computer and make sure none is on the USB device and format it. Once formatted, try turning it on again, if it works, copy your music over and try again. If it does not work, it is likely faulty and should be returned.
Sep 07, 2007 | RCA Lyra Th1032 MP3 Player
Why cant i put songs i removed back on
This player can only handle songs that are in a specific bit rate - lower it to the rate suggested in your product specs. Go to RCA's website if you have lost the documentation. Corrupt file systems can usually be solved with a firmware upgrade (also at RCA's website), but if that fails:
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
May 28, 2007 | RCA Lyra RD2763 MP3 Player
60 people viewed this question
 Grubhead
Grubhead
