actually, the only way to fix this delicate piece of machinery is to replace the whole heater core unit. its the safe and best way. here are some step by step
instructions on how to remove the old one. i also included instructions for installation of the new core as well. a fix ya rating would be most appreciated.
Remove the Old Core
Step
Drain the cars
engine
coolant from the water pump (remove the surge tank cap and drain bolt).
Disconnect the heater outlet and inlet hoses by removing the clamps.
Step
Disconnect the Body Control Module. With the battery disconnected, parking brake on and
transmission
in Neutral, detach the entire front console, pull back the carpet to
the right of the left dashboard support bracket and remove all the
BCM's connectors and retainers.
Step
Pull back the carpet below the left dashboard support bracket. Remove
the gas pedal from the front of the dash, then remove the center floor
outlet ducts. Disconnect the main center floor duct from the heater/air
conditioner module.
Step
Remove the heater core cover, from the HVAC module, sliding it away
from the module locating pins and rearwards until the drain tube clears
the dash front. Remove the heater core from the cover.
Install the New Core
Step
Install the new heater core and reconnect the core cover. Use a new
drain tube seal on the drain tube. Spray the core seal and dashmat with
soapy water to make installing easier.
Step
Reattach the center floor ducts and the gas pedal. Install the Body Control Module and the front console.
Step
Connect the outlet and inlet hoses to the heater, replace the surge
tank cap, fill the cooling system and connect the negative battery
cable.
Step
Operate the cars engine until it reaches normal operating temperature.
Watch over the climate control operation and check for any leaks.
