Configure the router
Pc troubleshoot
I Have Program Hack,,,With Remote Control But This Remote Not Working ??????
Posted on Feb 19, 2008
On my Compaq Presario C700 Netbook PC laptop, I am connected to the wireless router, but not the internet. I plugged a cord directly into my laptop from the router, but still no internet access! Why did...
It seems to be a router configuration problem.
Please connect to your router ip adress via browser and correct the settings or run the configuration wizard to configure it.
Let us know if you still have any problem
Aug 03, 2011 | Computers & Internet
Cannot connect notebook to wireless connection at home
Check IP configuration at router and your computer end. Follow if router is configured DHCP then you no need to configure IP in pc and if router is confg Manual IP then check LAN settings of router and follow IP class and put IP in your pc. Also check securities in router.
If you r unable to find anything, contact your service provider and some other technical engineer.
Regards;
Hasan
Dec 27, 2009 | Computers & Internet
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Trying to switch routers, can't get into new Netgear to configure
To configure it you can simply contect a pc to one of its rj45 port. it will give the pc an ip address in a default range. but the must have its network connection configured to receive ip automatically.
See the status of the pc LAN connection and note the gateway ip address. then type this ip in your explore address bar to access the configuration page / program of the router.
Hope that help.
Mar 16, 2009 | NetGear RangeMax WPN824 Wireless Router...
My electricity went off and now my connection is open but my comp
You need to reconfigure the router. The power outage probably resetted the router to it's default settings. In the default state the router doesn't have any wireless security; hence the "unsecured network" warning from your PC.
Connect your PC or a laptop with a cable to the router, surf to (http://192.168.1.1 or https://192.168.1.1 - ignoring any security warning); which is the configuration interface of the router and follow instructions in the manual.
When you have a Linksys configuration CD, you can simply run the "Easy configuration" setup after connecting your PC with a cable to the router.
Plainly put you just have to configure the router just like when you first used it.
Feb 09, 2009 | Linksys Wireless-G WRT54G Router
3CRWER100-75 no DHCP IP on child routers
router 1 (base) router 2 (repeater) router 1 (base) is the network, the SSID is where u get your internet connection set router 2 with same SSID, DHCP on. i advise connecting hardline to make sure both routers are working correctly. once thats verified then go wifi
Jun 30, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
Configuring of ISDN Router
you can telnet by going to Start, run, type "telnet 192.168.1.1" hit enter a black window will open and your in the router. Youl have to call your ISP for the propper settings.
Aug 29, 2007 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
230 people viewed this question
Alun Cox
David Payne
David Payne
