Question about JVC TH-M303 System
No sound only getting sound through the headphones, just quit working one day! Also how do i get the dvd player to just use the T.V. speakers? cause everything else works accept the sound, should still be able to watc movie and use the t.v. but can't figure out the way...
  • Marbron Apr 02, 2008
    I have the same problem as jc-chris. After reading his comments I tried plugging my headset into the socket and hey presto.. Sound, even on my dvd. How can I fix this??????????????????
  • sferris Jul 25, 2008
    I have exactly the same problem. The Sub seems to have decided to go on a break. Any new ideas are welcome!
    Scholar:
  • 103 Answers
Look through the menus on the TV. There is probably a setting that allows you to turn them off and on.
Hope this helps, and please rate my advice, good OR bad.
Posted on Feb 04, 2008
Can/how do I get sound to play in factory dvd player (2002 Envoy) without using headphones?
If you have an active headphone jack, just plug in some PC speakers. I don't know how best to mount them or what kind of volume you'd get out of them but that would be quick, cheap, and easy.
May 20, 2014 | GMC Envoy XL Cars & Trucks
The main speakers don't work. Headphone jacks work but if you unplug the headphones there is no sound
Make sure that you don't have mute on, and make sure your TV speakers are turn on. Go to menu and see if there is a way to turn your internal speakers on. If you can't fine anything , then your audio processor could be locked up, and if you unplug your TV for 30 MIN. it will reset the processor back to normal. Good luck and have a nice Day. If all that don't work, then your headphone might not be closing when removing the jack.
Oct 16, 2010 | Panasonic DVD-LS86 8.5 in. Portable DVD...
2005 dodge caravan, factory dvd... no sound through speakers
My grandcarvan sxt came with a remote for the DVD system and wireless headphones from KOSS. You have to press the headphone button on the remote to change it to headphones otherwise it comes through the main system. With the button pressed we can listen to cd or radio in front while they wear the headphones in back. You might need the remote to change it back to main system. The headphones from Koss are lifetime guaranty and not too expensive.
Dec 06, 2009 | 2005 Dodge Grand Caravan
How do you work the sound on the DVD player?
I have a 2005 with DVD - but do not have the wireless headphones. I use the AUX button on the front radio to switch between FM/AM/and the DVD Player. I do have headphones jacks in the roof console by the DVD player, but have never used them.
Aug 06, 2008 | 2006 Chevrolet Uplander
Concept mobile dvd
I have a Concept DVP 500 dvd player the audio quit working through speakers, was programmed for a certain station. what could the problem be or solution to fix it
Apr 07, 2008 | Concept Slot Load Half-Din DVD Player Car...
Ford F150 DVD Player
i have a 2005 f-150 and it was bought used, no wireless headsets and remote but i learned if you push buttons 2 and 4 together on the cddeck you can use the radio through the speakers and the kids in the back can used the headphone jacks to listen to the dvd player.
Jan 25, 2008 | Car Audio & Video
Poor sound quality/Speakers not working
That might be because :
-Your using a burned DVD
-It's just a piece of shit
-You need new headphones
Dec 27, 2007 | Durabrand 8.5'' Portable DVD Player
There is no sound
Have you recently used headphones in this device? I have a portable DVD player that had a similar problem. It thought that headphones were plugged in and that turned the sound in the external speakers off. If i plugged in headphones the sound worked in them. So I jiggled the headphone plug in while in the jack and removed it and the sound came back on.
Dec 10, 2007 | Durabrand DUR7 Portable DVD Player
Sound wont work right /not much at all
Headphone connector is usually designed to pass audio to speakers when the headphones are disconnected. A corroded or bent connector will lose audio. Does the headphone audio level seem ok? Try inserting and removing the headphone jack several times to clean the connector.
Nov 30, 2007 | Protron PD-800 DVD Player
No sound whatsoever on my dvd player.
These units have a remote which provides controls not on the player itself. Be sure to check that the mute is not on. The other obvious question (but it still needs to be asked) is have you checked the volume control setting. When you move the control do you hear static or anything over the speakers which could indicate a bad volume control. Have you checked audio with headphones? If you have sound with headphones then you may have a loose connection in the speaker wiring or the headphone jack may be malfunctioning.
Feb 18, 2007 | Initial IDM-7110 Portable DVD Player
JVC TH-M303 System Logo
106 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
