Question about Eureka 5892AVZ Bagless Upright Cyclonic Vacuum
Eureka 5892BVZ ON/OFF switch burnt
My 5892BVZ stopped working and I checked the wire connections on the on/off switch and the black wire connection was burnt at the connection point and the wire melted about 2 inches down. Is there anyway to get a new wire harness? Or can I splice the wire with a new connector?
  • 6 more comments
  • Andy10917 May 24, 2008
    We had the same exact problem with the same model, but the purple wire was the one that was burnt. Stripped the wire back past the burned spot, with a new push-on connector. It didn't work - I thing the switch is NG, and the wire may be a symptom.
  • Anonymous Aug 14, 2008
    I have the same problem! I took it apart and replaced the connections and was only able to make it work if I tugged on the wires. I called about a replacement part. I think they said $30+. You have to replace the housing around the switch...its one part. I'm still looking for a cheaper alternative.
  • noegoeo Dec 30, 2008
    I had the same problem with my vac (purple connector). I replaced it after a trip to the electronics section of my local hardware store. Unfortunately when the switch burned-out (and the handle heated-up) I believe it created more damage to the switch itself (via heat) and to the trip switch that gets used when you tilt the vacuum back to get it started because now there's an issue where it won't turn off.
  • Anonymous Feb 21, 2009
    The on/off switch is burned out. What is the part number of the switch and where can you get it besides Eureka?
  • Anonymous Feb 28, 2009
    Handle was getting to hot to hold and black wire burned off. I cleaned and reattached wire, but switch did not work properly afterwords. I can't seem to find a switch anywhere.
  • Anonymous Mar 22, 2009
    It's unbelievable that we are all having the same pronlem and nobody has been hurt, these are real fire hazards!
    I hope Eureka considers a recall or offers to replace these faulty switches; the alternative is probably a class action once someone get hurt.
  • Anonymous Apr 12, 2009
    5892BVZ ON/OFF switch burnt _ I rewired to only find out the Switch is No Good. Where can I find the Switch?
  • Anonymous Apr 25, 2009
    I have exactly the same problem with this vacuum. First the intense heat and then operation that does not allow me to turn it off without pulling the plug. The attachments to the switch actually melted and broke the black connection. I can replace the attachments but I do not know where to find a replacement switch.
    Problem Solver:
  • 13 Answers
COUNT ME IN ON A CLASS ACTION IF ANYONE KNOWS A GOOD LAWYER.
Here's my story, posted on other solutions here, especially on the Model 5893; many people with burned wiring and switches. Major fire hazard imo! Okay, here's the skinny on my upright Eureka POS vacuum:
Had a problem with my upright Eureka Model 5893 bagless kinda starting and stopping. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Posted on Jan 30, 2010
You can file a complaint with the Consumer Products Safety Commission and maybe they will do something about this ****. I have the same problem as the rest of you. If they can make a stink over Toyota we can get some attention for EUREKA!!
https://www.cpsc.gov/cgibin/incident.aspx
Posted on Mar 07, 2010
I just had this same problem with my 4 year old Eureka 4870GZ Boss Smart-Vac Upright Vacuum. The switch and attached wiring caught fire and melted. I will NEVER buy another crappy Eureka. Consumer Reports can shove it for recommending this death trap.
Posted on Jun 16, 2010
I also have a Eureka 5892 with burnt wiring in the handle and a bad switch. I called Eureka to ask if they improved the switch any. Of course the lady did not know. $30 to replace a switch on a ~$100 vac. Do you suppose Eureka wants us to throw these vacs away?
I'm going to just replace the switch with a completely different one, maybe even two if I want to isolate the brush roller motor.
If anyone gets a class-action, or even a recall started, count me in.
Till then if anybody DOES plan on throwing theirs away, I could use some other parts for mine (hose and accessories, etc). email turbovaculator at yahoo you know the rest.
Posted on Dec 15, 2009
I also have a 5892bvz and smoked wiring, the handle would get so hot you could not hold it. You can get the switch here for $9 http://www.totalvac.com/27871-1.html I will Never buy a Eureka. I can tell you this, I splurged and bought a Dyson from Khols on sale and using a 30% off code on the web, got it for $300 delivered. It's the purple ball version and it rocks. Quite, fantastic sickroom power, super easy to clean.
Posted on Aug 07, 2011
  • 126 Answers
You can splice the wire but be careful to do it properly. If the wire has a push on connector, you should replace the connector and use a heavy gauge wire with a properly insulated connector, be it a crimp style or a wire nut. A couple wraps of electrical tape around the connector is a good idea too.
Posted on Feb 02, 2008
  • kenmtb Sep 03, 2010
    I have encountered the same problem on a Boss Smartvac. It looks like the power switch's push on connector was poorly spliced. This would make a high resistance connection which will generate a lot of heat. The heat will ruin the wire and any insulation near by. If you do repair your switch, I would suggest replacing any bad section of the old wire by soldering in a heavier gauge braided wire. Also replace the connector and solder it to the new switch. Use heat shrink tubing to insulate. This should remove the high resistance points. This place appears to have a smartvac replacement switchhttp://www.totalvac.com/39455-1.html
My vacuum stopped powering on
sounds like u have a problem with the plug or wire. they can get broke also u might have to take switch out of vaccum because it could be bad or a wire is not making good connection
Apr 10, 2014 | Eureka Vacuums
I have an open in the black wire leading down to the carpet sweeper (after the handle), thus the motor wont turn on. how do i get to the wiring to re-run a black wire?
Did you test the wire with the switch in the "ON" position. If not, try it before opening the handle.
The problem is more likely to be a worn out or broken switch, including a reset switch.
Also try connecting the hose directly to the power nozzle. If it works, then the problem is problem a loose or burnt out connection in one of the wand connections. Check connections for discoloring.
Jan 01, 2011 | Kenmore 28015 Bagged Canister Vacuum
The handle for my Eureka 5893 AVZ was getting very hot. Finally, the wires around the switch melted and the vacuum will not work. What is wrong? Is the switch bad? Nothing else appears to be wrong.
usually if a connection gets hot enough to start melting it is usually a loose connection or high current. more than likely the switch is bad if you replace it with the same type of switch and it gets hot check the motor. make sure it is clean and isn't jammed
Nov 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Oct 02, 2009 | Vacuums
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
Handle gets very hot on my 5892BVZ vac
i have a 1998 chrysler sebring convertible stop starting by the ignition switch,we changed starter,ignition switch been changed,changed starter relay,trace the wire haven't found a broke are burned place in it,checked igniton fuse its good,didn't see a linkable fuse
Sep 23, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
My vacuum (Eureka Bagless Model 2961 AVZ) will not START!
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Jun 11, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Vacuum turns on then off in a few seconds.
check the electrical connections at the switch and at the incomming power cable because they get moved about a lot the wires become broken inside the insulation or wire jacked. gentally pull on the wire to see if it has a rubber band stile action if so remake the conection. as for dirt in the switch use a tech cleaning spray ( super wash ) to clean out the dirt from the switch.
May 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Cords for an Eureka Oxygen 6992A
Yes, that short cord in the power nozzle can be replaced and BOTH wands should also be replaced, not just the one that appears burnt. If your locan vac shop won't fix it, contact Eureka at the customer service number on the bottom of your vacuum. They will most likely set you up with the correct parts.
Oct 19, 2008 | Eureka Oxygen s 6992 Bagged Canister...
Eureka Boss vacuum just quit
You have a clog in the hose (or somewhere) most likely the hose though. Find the clog -clean it out-let the machine cool down and you are back in business. This is really a good feature of the Eurekas because rather than continue to run and burn up the motor it shuts off -you clean it out and your vacuum is saved.
Sep 08, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka 5892AVZ Bagless Upright Cyclonic Vacuum Logo
1,387 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
