Question about Panasonic KX-TG6021 Cordless Phone
Cannot call out or answer a call
I get a dialtone and hear the numbers dial but it never connects, dial tone just continues. Also when receiving a call, I cannot hear caller , but they can hear me. True for all three phones. (Used to work fine, just started happening a month ago.)
  • 3 more comments
  • Anonymous Feb 18, 2008
    on mute must get it off don't know how
  • Anonymous Mar 26, 2014
    If I press call button the phone is quiet - no ring tone (or caller if answering a call). But when I press the speaker key everything can be heared. It's as if it's switched off, the volume is turned up to max.
  • Anonymous Mar 30, 2014
    When i pickup phone to dial I hear too many beeps. How do I decrease the 3 of beeps before dialing my number?
    When I pickup phone to dial i hear the dial tone but it beeps too many times. How do I decrease the number of beeps?
    i cannot use my phone to call or to receive calls. there is no dial tone. I have followed all the instructions in the manual.
  • 65 Answers
The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
Posted on Feb 05, 2008
  • richard shaw Oct 09, 2012
    i have no setting for touch tone /pulse ?? - other non hands free phone works therefore presume problem with this phone only
Why no dial tone. Only static?
Check the phone line were it comes into the house there is usually a point where the phone connection from the the TELCO outside wires connects to the inside wiring.
Remove the inside wiring and test the wiring that is on the TELCO side. If you get dialtone the trouble is in the inside wire. If you don't get dialtone call TELCO
Aug 26, 2014 | Lands Phones
I cannot get a dial tone it sound like the line is stayed open
Cellular phones to not use tone dialing. If you hear a dialtone at anytime it is simulated by your phone company however their is no dialtone.
Dec 23, 2010 | Cell Phones
I have no dial tone on my fax machine and i cant send or receive faxes
Remove the phone line from the back of the fax and connect a standard phone (not a business PABX or PAX system phone) to the line. Ensure dialtone is available. (Make sure in doing this that you are also testing the cable from the phone socket to the fax). If no dialtone, replace cable or fix line.
Check that the line is connected to the 'line' port on the fax, not the 'phone' port.
If still no dial tone, it may be modem fault (in the fax). Seek specialist attention.
Feb 12, 2010 | HP 640 Inkjet Fax Machine
Lately every call I get I lose and receive a dial tone I am with bell but they say it is my phone possibly a software issue
Well, interesting part is, your phone doesn't create the dial tone sound.
If your call is ending, then you hear the dialtone, I would suspect a problem with a particular tower. If it happens all the time and in multiple areas, then all bets are off.
Nov 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
No dial tone on my Lexmark X4270
There are two outlets in the back where you plug in your phone line. I had the same problem when I
was plugged into the far left plug (as you are facing the front of the all in one). I switched to the other
outlet and it worked fine. But still once in a while it seems to loosen up and I have to push it back in
farther. Today I got a dialtone but could not send a fax. I got a dialtone but still wouldn't send. So I
checked the outlet and sure enough, it was just loose enough to prevent the machine from registering
the fax number, but connected enough to get a dialtone.....go figure. Good luck
Apr 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Fax not going out/coming in
connect a phone with 4521 in the back side jack of phoneout,
for outgoing fax
place original in the adf or glass for fax
Press hookdial and dial your sending fax number in 4521 after number dialing pull the phone handset to ear when you leason fax tone from the dialing number press start button to send fax.
for incoming fax (in not automoated)
press hook dial and press start to receive
Mar 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
No dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
Jan 19, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Dialtone
http://www.retrevo.com/samples/GE-manuals.html
follow the link above and also try to get an earlier or newer moddel manual ;) take care
Oct 22, 2008 | Uniden Cordless Phone
Can't dial out
Can you hear the tones when you dial? Is there a (tone / pulse dial) switch or programming option?
Jul 02, 2007 | Uniden DXAI4288-2 Cordless Phone
Panasonic KX-TG6021 Cordless Phone Logo
462 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
