Ok i need to put the things on the side of my air comditioner because mywindow is a bit bigger than the air conditioner itself (i dont know what they are called) and i dont know what holes to screw the screws into on the air conditioner because i have the screws that it came with nad everything that i have tried the screw does not fit please help me
  • 139 Answers
That is a good question...what to call them...perhaps adjustable baffles? Anyway...have you removed the air conditioner from its housing? Most window air conditioners can be removed from the housing through the front opening. With the air conditioner may be possible to apply the screws from the inside of the air conditioner housing to attach the baffles to the outside. I may be able to give better advice if you can tell me the manufacturer and model number of the air conditioner.
Good luck... and I hope this is helpful!!
Posted on Feb 01, 2008
Hi, I have a fujitsu asu36clx1 air comditioner. When the unit is off it stills pulls 215 watts. Is this normal?
First of all how is it you determined it is still drawing wattage? Do you mean amps, Are you using an induction meter ?
Nov 07, 2014 | Heating & Cooling
Hair window air comditioner is making funny noises
Hello, the noises you are hearing can be a few differant things. It could be the condensate being pcked up and splased on the condenser which makes a swishing sound, this is normal. It could be the fan blade hittting the shroud and that happens when the fan gets loose on the shaft. It also could be the compressor itself if liquid refrigerant is entering the compressor,
May 13, 2012 | Haier Mechanical Air Conditioner HWF05XC7
My amcor is leaking water!
Please be a little more specific because Air Comditioners do in fact collect moisture from the air. This water collects in the drain pan and drained ouined off outside. If the leak is inside, the unit is not tilted to direct the water towards the drain hole.or the drin itself is plugged .Check and let me know if the problem still exists. :-) Ned
Jul 06, 2011 | Amcor Heating & Cooling
Water dripping inside window opening
I would make sure the 'drain hole' is clear and not stopped up. Sounds like it could be stopped up and you have so much water in the unit it's over-flowing and coming out inside the window.
hope this helps.
p.s. one other thing - you might need to put another hole in the unit (to allow better draining). Typically these units just drip water outside and putting (with a drill) another hole in the bottom of the unit to allow better draining is easily done.
Jun 14, 2010 | Fedders A6X05F2G Wall/Window Air...
Blowing water
Window Air conditioners need to tip back just a bit in the window...if they are flat or tipped front you will have the water problem...
Here also is a tip that will help you to keep you Air Conditioner running well...
Window Air Conditioners - Clean them every year
May 07, 2010 | Haier hwr10xc6 Air Conditioner
How do i connect air conditioning outside unit to the inside unit, can it be done with out a vacuum pump
By the book no, However production is another thing, reality is, very few new homes are ever evacuated, if at all they are purged with refrigerant a bit, If me I would do it, if unable , purge a bit.
Apr 24, 2010 | Heating & Cooling
Window Ac is not colloing properly even after refilling freon gas
well if ever thing is working ok after fill freon. start with cleaning both coils dirt can stop air flow .
Mar 24, 2010 | LG Electronic Window Air Conditioner
I don't have a double hung window. my window opens from side to side. How do i use my air conditioner in my window?
Common problem. When you open the window will your ac fit side to side. If so. You will have get a piece of plywod to blank of the other part of the window. If your window unit does not fit. The only other thing you can do is buy one that fits. Rus
Jul 04, 2009 | Daewoo Heating & Cooling
Turn on the and it begins to cool for about 10
Possibly your compressor overload is bad. A cheap and easy to replace part mounted on top of the compressor.
Jun 05, 2009 | Heating & Cooling
My sumsung air conditioning window unit its frozen like a block of ice. what do i do?
Check if the air filter and evaporator coil if clean, check also the blower is operating. If every thing is "ok" then maybe your unit is under charge you need a qualified technician for this problem.
Sep 12, 2008 | Samsung Heating & Cooling
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
