Kitchen Appliances - Others Logo
Posted on Jan 02, 2010
Toastmaster bread box-What number should I cook banana bread with baking powder and soda? Model 1154 I don't have the manual. I used recipe from magic chef manual--banana bread-quick bread
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
260
Points
Here's a link with the model's recipe book.
Good luck on your next batch (assuming you already baked the one from early in the month-lol).
http://kitchen.manualsonline.com/mdownloads/1e71dde0-c2a7-4eef-b260-28275af1aeb2.pdf
3answers
Recipe for Banana cake made with sugar substitute pleaseRecipe please
Go to Google lots of recipes and videos. :-)
Jul 24, 2019 • Baking
Im looking for a receipe for bannana bread
Make Delicious Homemade Banana Bread
Cooking your own banana bread from home is a relatively straightforward thing to do, although it does require a couple of moderately advanced techniques such as creaming butter by hand and folding ingredients together.
BBC Food states that you can prepare your banana bread in under 30 minutes, while cooking time lasts between 30 minutes to an hour in order to produce a delicious loaf of homemade banana bread.
Preheat the oven to 350 F.
Sift your flour, bicarbonate of soda and salt through a sieve and into one of the two mixing bowls, ensuring that you eliminate all clumps and are left with a fine powder in the bowl.
Allow your butter to reach room temperature before creaming the butter and sugar together in the other mixing bowl.
Swirl the wooden spoon in a circular motion to beat the butter and sugar into one another for at least a minute.
The creaming process is finished once you are left with a light and fluffy, even mixture.
Crack open both eggs and add them into the creamed butter and sugar.
Peel all four bananas and lay them flat on a chopping board before mashing them into a pulp using the potato masher.
Add the mashed banana into the mixing bowl along with the buttermilk and vanilla.
Mix these ingredients together using the wooden spoon before adding the flour, bicarbonate of soda and salt from the other mixing bowl.
Fold the contents of the bowl using the large metal spoon.
Many chefs use a figure of eight movement, cutting through the surface of the liquid with the leading edge of the spoon remember that the objective is to keep a much air in the mixture as possible, so you should look to turn over the spoon as you complete figure of eight motions, thus replicating a folding motion.
Grease the loaf tin using a small amount of butter or oil, as this will prevent your banana bread from sticking to the tin after you have baked it.
Pour in the ingredients from the mixing bowl, taking care not to spill any or make a mess.
Wait for the liquid to level off so you have a flat, even surface and insert into the oven to bake for approximately 1 hour.
Remove your banana bread from the oven when it has risen and turned a golden brown color. Allow the bread to cool in the tin for 2 minutes before turning it out onto a wire rack and allowing to stand until cool.
2answers
Can anyone give me an easy chocolate cake recipe to make with my kids?
Try this one; http://www.bbc.co.uk/food/recipes/easy_chocolate_cake_31070
I find the BBC recipes are really easy to follow when you have kids 'helping' you in the kitchen. Or you could try this one-bowl recipe; http://planningwithkids.com/2011/04/03/easy-chocolate-cake-recipe/
Feb 25, 2013 • Cooking
Toastmaster Bread Box #1142 - series KW27620401. Bakes great except bread really sticks to the pan. Has to be cut out. Don't know part number of new pan, but is replacement the best solution?
Can you send me the recipe you used and also tell me the kind of flour you used?
Please send what was written on the bag.
...in other words does it say "all purpose flour",,,,,"bread flour" etc.....
Thanks I hope I can help you
1helpful
Oster 5838 and a good banana nut bread recipe
CookingCindy 1 Solution July 23, 2009 I have made the following recipe in my West Bend machine with great results. I just got a Sunbeam 5895 at a garage sale - it works great - just wanted a different "shape" loaf! I'm going to use this recipe in my Sunbeam - don't see why it won't work! Here's the recipe! 1/2 cup softened butter, cut into small pieces for good blending 1 cup mashed ripe banana (personal note: if my ripe bananas don't measure up to 1 cup, I add enough milk to make it 1 cup. Seems to be okay) 2 eggs, large, slightly beaten 1/2 cup chopped nuts (optional) 2 cups all purpose flour 3/4 cup sugar 1 teaspoon baking powder 1/2 teaspoon baking soda 1/2 teaspoon salt Grease inside of pan and knead bar generously with vegetable shortening (I just spray with Pan Spray). All all ingredients in order listed above to pan. Lock pan into bread machine. Program for quick bread. After a few minutes of mixing, I usually take a rubber spatula and scrape down the sides and stir in any flour that has not been completely mixed. I didn't do this once and ended up with a loaf that had flour coated corners! Good Luck! Enjoy! Just follow the above recipe but if your using the Oster 5838 expressbake put the setting at expressbake 80min. It works flawlessly, also with the oster 5838 expressbake you don't need to use the rubber spatula to mix after a minute because it blends everything together nicely. Thanks bobert.
6helpful
Banana bread recipe for sunbeam 5895
Here's the recipe!
3/4 cup sugar
1/2 teaspoon salt
Good Luck! Enjoy!
2answers
I'm in need of a user manual for a toastmaster bread maker model 408598
Hi allergy mom,
For recipes, I'd start with the following:
http://www.globalgourmet.com/food/egg/egg0496/potbread.html
http://glutenfreemommy.com/category/bread-recipes/
http://allrecipes.com/Recipes/Healthy-Cooking/Gluten-Free/Bread/ViewAll.aspx
http://www.glutenfree.com/info/Recipes_Other.aspx
http://www.celiac.com/categories/Gluten%252dFree-Recipes/Gluten%252dFree-Bread-Recipes/
http://www.kidswithfoodallergies.org/pumpkin_bread_recipe.php
For Toastmaster parts, service or manuals, go to
http://prc.prodregister.com/prodprotect/applica/
And click on "toastmaster" (lower-left portion of the page), it redirects you to a secure webpage where you can register.
https://secure.prodregister.com/prodprotect/applica/tm.shtml
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
1helpful
4answers
Instruction Manual
go to hillbillyhousewife.com and they have instructions for bread machines. I have used 3 different models of breadmachines and they work about the same. The site also has recipes. I use this recipe most of the time for fast bread that takes one hour for the Toastmaster TBR15.
I cup plus one tablespoon warm water - I use warm water from the tap but you can use a cooking thermometer if you like.
2 tbs oil
2 tbs sugar
1 tsp salt
3 cups white flour OR 1 1/2 cups white and brown flour
1 tbs yeast
Adding glutein will make the bread have a smoother texture. Follow the directions on the box.
Add ingredients in order.
Program breadmachine to fast bake and let it go. You will have fresh baked bread in an hour.
Hope this helps
Jan
Top Toastmaster Kitchen Appliances - Others Experts
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
