Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Oven fan oveen fan comes on when bake or convectin bake on and won't go off until oven cool.
  • 2 more comments
  • Lovetocook Feb 05, 2008
    Feb. 5, 2008
    I'm having the same problem with my oven as well. The fan turns on as it pre-heats and will not turn off until it cools down. What's the matter and how do we fix the problem?
  • d fresh Feb 13, 2008
    oven fan comes on during baking and stays on till very cool
  • d fresh Feb 23, 2008
    fan comes on
  • joe runco Feb 05, 2012
    front face gets hot just changed clock and front panel noticed cooling
    fan not coming on. but I can turn it on in testing procedure
  • Jenn-Air Master
  • 2,651 Answers
You dont fix it its working fine, the fan comes on at a predetermined temp and doesnt shut off unit l cools to a certain temp as well , its to protect electrical components from overheating. every new stove does it has to happen!!
Posted on Feb 23, 2008
Oven shuts off while baking will not come back on until it cools off
sounds like ur oven sensor to me check with a multi meter
Sep 11, 2014 | GE Ovens
Fes367dsa fan runs while baking but it is not a convection oven
Chris Lindstrom,
I understand that you have a fan running while you are baking. This is a totally normal function of your applliance. A cooling fan may automatically turn on and off to cool internal parts. It is normal, and the fan may continue to run even after oven is turned off.
-Best Regards-
Jan 15, 2014 | Frigidaire FES367 Electric Kitchen Range
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
After baking at 425 degrees, ew30mc65js2 will not shut off - fan continues to run and some heat, although lower, continues after 1.5 hours
Hi - if you still have your user manual I think you will find that oven have a time delay designed into the electronics for cool down purposes after the cycles completed. If it does shutdown after say 1.5hrs, it may seem a bit long but its actually doing what its designed to do, it should not be heating but circulating the hot air thru the oven.
We use to have a similar problem with our F & P BI600 wall oven - what we've done is have the door slightly ajar to quicken the cool down process until one day the fan ran continously - then I had it disconnected.
I hope this may help with your situation, if its running continously then its best to disconnect the cool down fan, the bake fan is normally on a separate circuit and not affected.
Jul 13, 2011 | Electrolux Ovens
Need the recipe for the cake mix that come with the oven
This is just one of many I found at this website
Children's Chocolate Cake Mix
1 cup sugar
3 tablespoons unsweetened cocoa powder
1 1/2 cups all-purpose flour
1 teaspoon baking soda
1/2 teaspoon salt
1/3 cup vegetable shortening
In a medium bowl, combine sugar, cocoa powder, flour, baking soda and salt. Stir with a wire whisk until blended. With a pastry blender, cut in shortening until evenly distributed and mixture resembles corn meal. Spoon about 1/3 cup of the mixture into each of 11 small containers with tight fitting lids or Ziploc bags. Seal containers. Label with date and contents. Store in a cool dry place. Use within 12 weeks. Makes 11 packages of Children's Chocolate Cake Mix for Easy Bake style oven.
To Use:
1 package cake mix
4 tsp. water
Mix together and stir with a fork or spoon until blended and smooth. Pour mixture into greased and floured 4 inch round miniature baking pan. Follow directions for child's oven, or bake in mom's preheated 375* oven for 12 to 13 minutes. Remove from oven and cool in pan on a rack for 5 minutes.
Invert onto a small plate and remove pan. When cool, frost with Children's Chocolate Frosting. Serves 2 children.
Jan 29, 2011 | Fun Rise Disney Princess Cool-Bake Magic...
Should the fan on my built in electric convection oven come on during normal 'bake' mode (ie not 'convect' mode ?
There is a fan for cooling down whole oven, it can turn on and off during the regular bake or broil cycle to cool down the oven on the outside. It's controlled by its own thermostat, so it will even stay on for awhile when you turn the bake off.
Mar 03, 2010 | KitchenAid KEBC107 Electric Single Oven
Oven appears to remain on after the baking process is finished. It is a brand new Frigidaire double oven and we have just used it for the first time.
What is staying on? If you are hearing a fan staying on, don't worry about it. Some ovens have a cooling fan that continues to run until the oven cools down below a certain temperature.
Dec 22, 2009 | Blenders
Convectin fan in Jenn Air Stove
sounds like the fan or motor is not working at all. have a technician replace it.
Mar 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Fan won't turn off even after day and disconnecting power a number of times
if you talking about you convectin fan you proably have a stuck realy in the control bd and will need to replace it
Jan 30, 2008 | Dacor Epicure 30" Double Wall Oven,...
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
116 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
