Question about Altec Lansing VS2121 Computer Speakers
One speaker not working
I turned the volume (on the computer) down to nothing, then increased it again, and only one speaker came back with sound. The other speaker has a hissing sound when you put your ear to it, but no music comes out of it!? Have worked fine for 2 years, so can you please tell me what might be the problem?? I have unplugged and retried to no avail. Hope you can help! I have had a pair of Altec Lansing VS2121 speakers for about 1-2 years and have worked great. Until one day I had turned on my comp and only one speaker was working, weird part is that the none working speaker is the one that has the controls on it (volume, head jack etc.) my problem comes when I attempt to open it up to see what exactly is the problem, there doesn't seem to be a way to open it without breaking it or if its just all glued together. There are no screws that keep the cases closed just a little grill looking thing covering the speakers which have 4 screws but cant get to the volume controller part. If anyone has opened one up or has any suggestions please let me know. Thankyou much.
  • Anonymous Feb 15, 2009
    i have 4 speakers 2 of them are not working
I called Altec Lansing Technical Support:
Altec Lansing
535 Route 6 & 209
Milford, Pennsylvania 18337-0277
T. 866-570-5702
T. 570-296-4434
F. 570-296-6887
They stated that the case is not made to be opened (Great Design...NOT!) They suggested I remove the sub-woofer cable and clean the pins with alcohol. Of course, you should remove the AC plug first.
One other suggestion I would make as a last resort, for this and other problems. With the unit unplugged, pull off the Volume Control Knob, and the sfx knobs.  Spray electrical contact cleaner in the openings, and hope it reaches the dirty areas.
Make sure all the cleaner has evaporated before reconnecting the unit.
Good Luck
Posted on Feb 13, 2008
    An expert who has answered 500 questions.
  • 620 Answers
First things first:
1) check your speaker for good connector, and all is working is playing fine.
2) check if your warranty covers one SPK. or RMS
other than that ,
Good Luck
Posted on Feb 01, 2008
Why does my speaker does not work ?
You need to go to Settings on your computer and then go to Sound and check that your speakers are connected to your computer. Also, try to increase volume on your computer. Maybe your volume was turned down.
Jun 30, 2014 | Panasonic Toughbook CF-30 Notebook
Hello ! I have a Sony DAV-DZ640K Home Theater System, the problem is that I can increase and decrease sound levels for individual speakers, like i am able to increase and decrease surround (back) speakers...
Sound distribution varies according to speaker configuration. You have to select speaker size and placement and a number of other characteristics to get results. A review of the setup instructions in accordance with the physical size of the speakers you are using and nominal impedance values may help.
Feb 26, 2014 | Sony Audio Players & Recorders
Can't hear the skype ring when a call comes into my computer.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
Feb 13, 2013 | Computers & Internet
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
Jan 25, 2013 | HP Compaq Presario C769US Notebook
The sound in the left speaker goes on and off on rough road. turn the volume up to max it works. Turn down 2-3 and no sound
Jun 29, 2011 | Car Audio & Video
My Acer Aspire One PC Notebook speakers stopped working
The computer employs hotkeys or key combinations to access most of the
computer's controls like screen brightness, volume output and the BIOS utility.
To activate hotkeys, press and hold the <Fn> key before pressing the other key
in the hotkey combination.
<Fn> + <F8> Speaker toggle Turns the speakers on and off.
<Fn> + < > Volume up Increases the sound volume
(only for certain models).
<Fn> + < > Volume down Decreases the sound volume
Aug 26, 2010 | Acer Aspire One PC Notebook
Speaker volume too loud
Have you tryed to turn down the sound volume on the media player its self as well as the the main volume?
Jun 21, 2009 | Dell 5650 Computer Speakers
Speakers work fine,then they stop working...
This usually occurs if you have to much running in the background. Nothing to do with the speakers.
Try this;
start button>msconfig>startup tab>disable all (remember which you turned of so you can turn them back on later. Now reboot and then try your media player. If they work fine now, you know you are running out of memory. Either turn on only essential programs, or increase your computers ram (memory)
Apr 03, 2009 | Logitech Z-2300 Computer Speakers
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
May 07, 2008 | Logitech Z-5300 Computer Speakers
Find a friend who has an extra pair of speakers and try, but it looks like your speaker has a short/open Try your speakers on a different system, if the problem follows you, your speaker has problems. The cost of fixing theses might not warrant sending them out. Check your warranty. If you were cranking the volume, you could have blown the speaker driver.
Aug 29, 2007 | Harman Kardon SoundSticks Computer...
Altec Lansing VS2121 Computer Speakers Logo
1,386 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
