Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Monitor no signal
When pc turned on it comes on monitor no signal. any ideas?
  • Moliere Feb 21, 2008
    When i turn on my computer, my monitor is not responding (there is not power). I checked the plug. Everything is fine.
    What can I do? I don't have enough money to buy a new monitor.
    Thank you
Unplug the VGA cable from the PC, and connect the Power cable of the monitor to the power outlet. The monitor should intialize and return back to stand-by-mode (assuming that the power cable and internal fuse is ok).
If the LCD Monitor Power LED didn't change from orange to green even it was already push on, try to check the 2 schottky dual-diode (in TO-220 package, with heatsink), there is a possibility that one of this diode is open. Replace if defective.
Posted on Feb 26, 2008
I will check the back of the pc. the pc is just over 2 years old, it was working fine, i think when it starts up it is going through the normal motions but not a 100% sure.
Posted on Feb 01, 2008
    Novelist:
  • 139 Answers
Check to see if there is more than one 15-pin monitor connection on the back of your computer. If there is, try plugging the video cable into the other one.
Is this a new monitor? Was it working before this? Does your computer sound like it is starting up normally?
Optiplex 745 monitor goes to sleep randomly
In regards to your issue with your monitor: For a monitor to display "no signal input" there is likely a problem with the monitor making a connection to your input source (yes I know duh). First and easiest thing to fix this is to check your cables going between your computer and monitor, if your computer and monitor start out working and then fail to communicate, there is a good chance that the cable might be coming loose just enough that the connection fails. I might suggest that if you have, as you say another computer, that you try swapping monitors to check where the problem lies.
Hope this helps some.
Aug 12, 2013 | Dell OPTIPLEX 745 PC Desktop
I turn the monitor on and all it comes up with is an error message saying 'no input signals and that the monitor is going to sleep.' any suggestions?
It is either that it does not detect the video signal from your PC or there is a power supply problem in the monitor, you need to try it on another PC first before opening up the monitor. If it turns out to be monitor problem, please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 14, 2010 | HP L1940T 19" LCD Monitor
Emachine T6410 turns on but the screen says ''No Signal''
This problem is very common when you have a bad ram/ memory module or it is not making sufficient contact. Remove them and clean with a piece of dry cloth and reseated properly. Try it again. If it is still not coming on, the ram may be bad. Get them tested and replaced.
Thanks,
Lolita
Jan 05, 2010 | Computers & Internet
Hooked up a monitor and im not getting any picture. i just purchased the computer second hand today. i tried a second working monitor and still no pic. any ideas?..
Assuming that your monitors are good, if nothing is shown on the monitor, that means it does not receive any signal from the computer (or CPU). When you bought it, did they show you the computer and monitor are in good working condition (that means Windows desk top screen comes up on the monitor if it is a PC). If everything was OK when they showed you, but when you took it home, it does not any more, then maybe something became loose while transportation.
Make sure that when you turn the computer on, you hear the fan on the power supply and inside the computer running, and there should be some lights in front of the computer . If you do not hear anything nor see any lights in front of the computer then that is the reason nothing comes up on monitor. If it is the case, you may want to remove the cover of the computer and physically inspect inside the computer to see if anything becomes loose while transportation.
Just some ideas for you to work on. Good luck!
Aug 18, 2009 | Fujitsu Siemens SCENIC E600 Green PC...
I use a 37" lcd tv as a monitor for my t6528 e-machine pc. I turned it on one day and the screen was awash with a bunch of colors, then it crashed with "blue screen of death". Now when I turn it on the...
an easy way to check is if you happen to have a regular vga monitor, hook it up to the computer if you get same results then you'll need to get a new video card.
Mark
Apr 27, 2009 | E-Machines T6528 PC Desktop
I cannot restart my PC AllI get is a note saying NO SIGNAL ANALOG
i had a problem like that ,my tower got bumped and fell over. the heatsink and processor fell off. i had to remove processor (p4) from heatsink and make sure all the pins were straight and aligned properly. i cleaned both parts with alcohol. i then reinstalled processor(unlatched the arm )and it fell into place. then pushed latch down, installed some new thermal grease,installed heatsink ,plugged in and it worked- had a signal/ video again and able to use pc again.
Apr 07, 2009 | Gateway GT5058 Desktop PC
Monitor does not come on when powered on, it says no input signal
Check your video card. It sounds like it has went bad. Hope this helps.
Jan 08, 2009 | Gateway 420GR PC Desktop
Acer monitor lcd problem
Try the monitor with another known working computer, If ng there also, then have unit repaired under Acer warranty.
Aug 31, 2017 | Acer Professional P211 21" CRT Monitor
No signal on startup
if monitor is gave no siganl .Firstaly Check monitor Signal Cable For connected of ur system vga port. if Siganal cable is connected ur pc then Check ur System IF system is gave the Display anthore monitor . Then Proble is ur monitor signal Cable .So Plz Change Monitor Signale Cable.
Dec 29, 2007 | Princeton Digital VL2018W Monitor
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
