Question about RCA RT2500 System
No sound from speakers
I was given a rt2500 because it was buzzing through the speakers for 20 - 25 minutes till it warmed up. I found a post on this site about this problem and I replaced the 2 caps. that they said to replace and that took care of the buzz.However, when I hooked up the 2 front speakers and turned on the tuner I could barely here anything with the volume up all the way and what I could here kept cutting in and out.I checked the fuses and found that F106 and F107 were blown,I replaced them and then I got a lttle more sound but it still kept cutting in and out and then the fuses both blew again.
Please any help would be great. Thanks
    Brigadier General:
  • 6,966 Answers
On similar incidents, it would seem that the "finals" and some other components developed cold solder connections to the PCB. This of course would require re-heating with the use of a soldering iron. You may want to start with the brick looking transformer, the "finals" (underneath the big heatsink), power connectors and the relay.
From what I understand, this particular brand/model is susceptible to power outages or strong fluctuations hence you may want to use a surge suppressor once fixed.
After a repair/rework, it may be necessary to trick the unit into a reset. Hold the power button while unplugging the unit and plugging back in to the mains immediately.
All of the above would require that you be familiar/comfortable working with electronics circuitry and components, use of a DVM and soldering iron. Should this be not the case, perhaps your best bet would be to seek the services of a professional electronics/audio technician. In some instances, the cost of repair negate justification and perhaps a replacement may be the way to go.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
  • 749 Answers
The power supply unit has a problem... find the power sources and check the voltage, to determine the correct voltage see the capacitor's or Fuse voltage and compare it, source must not be higher than what is printed there.
Hope this helps.
    New Friend:
  • 101 Answers
Usually when caps are bad u can rest assure a resistor or diode in same area is bad also.most likey a res. look 4 burnt resistors
    Genius:
  • 3,422 Answers
HI,
This problem is CURED simply by replacing 2 capacitors inside on the main board. They are easily identified by a bulge on the top end of the capacitors. The capacitors are located between the heat sinks. The size is 6800uf/16v.
I bought one for myself. I have repaired only 2 that had the same problem as listed by above. They both are working great and for the record. . .are NOT pieces of JUNK,. . .hehe. . .they just need a little TLC. Parts available from larger electronics parts houses, not at RadioShack
You can even get the parts from www.partstore.com
Goodluck,
Don't forget to rate me as fixya..
    Scholar:
  • 128 Answers
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Surround sound doesnt work. When i switch the surround on there is a buzzing/ hum from the speakers. The sub has a hum in analog mode. I try to switch to theater, club, church etc. And still a hum was...
Back up, open the manual and set it up with test tones to verify the hardware before trying anything else. Then onboard FM. Then external sources (according to their manuals).
Hum/buzz solutions are common on the internet. Do some web searching for "audio system hum" to find somethign that matches your symptom.
Sep 01, 2011 | RCA RT2500 System
Buzzing sound coming from all speakers
Can't say for sure (not a lot to go off of) but whenever i hear a buzzing sound from my speakers, its because of a poor connection (broken/exposed/bent) of the audio cables (whether its the red/white, or headphone jack (computers)).
Oct 03, 2010 | RCA RT2500 System
A few weeks ago i would not get any sound then after the unit would warm up i would get a static sound for a while then it would clear up and be fine. Now no sound when i turn it on but after it warms up i...
Check all you wire connections to speakers and in the back of the receiver.If one is lose especially behind the amp it will create static noise..Did you move it around recently?It might have pulled a wire.Another thing that could cause that is build up of dust on the circuit board..Blow the inside out with a can of compressed air threw the holes in the side..Also check to make sure that in the wall outlet that you have it plugged into that its the only one there because that will also pick up static noise from the other accessories that you have plugged into it.Hope this helps you and have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Dec 07, 2009 | RCA RT2500 System
RCA RT2500 Buzzing Sound - Replace 6800uv 16v caps
I did it. I decided to go ahead with the repair myself. I have never done something like this before but it was easier than I thought. I filed off the old parts and soldered on the new. It works like a charm. Thanks.
Mar 14, 2008 | RCA RT2500 System
RCA RT2500 NO SOUND
Similar problem here, at first 20-30 min warm-up time, followed by irregularity in sound levels, to a complete failure after using for around 30 minutes after warm up (choppy sound to a steady buzz). I wonder if over heating has something to do with it since I left it on all the time after the need of a warm-up occurred. One night, a horrid buzz came from the system and ever since it would become unbearable to listen too after a few minutes, I am debating either to attempt a fix or chunk it. I haven't tried the caps and fuses yet, but seeing your problem leads me to believe it is something more to the problem, and more likely a better investment would be an upgrade.
Jan 18, 2008 | RCA RT2500 System
No Sound
Maybe the speakers are no good. Have you tried hooking up a different set of speakers?
Oct 11, 2007 | RCA RT2500 System
Static kinda sound
hi sounds like a earthing problem in the reciver or problem in the speakers try rotaiting the speakers back to front front to back left to right ETC.. good luck
Dec 31, 2005 | RCA RT2500 System
Rt2250 rt2500 speaker static noise hum buzz until fully warmed up
It sounds like a capacitor in the power supply is just about to die. With the power disconnected have a look at the large tin can looking gizmos near the power transformer. There could be a couple of them. Leave the unit switched off for a while before going near them they could still pack a splat. Replace them with the same value and make sure they're connected the right way and it should solve your problem. Whilst in there have a good look for any other smaller capacitors which look as if they're getting rounded at the top. Replace them too. Either that or dig deep and buy a new one.
Oct 23, 2005 | RCA RT2250 System
RT2500 speaker hum buzz until unit warms up
i have the same system that i bought new and after about 3 yaers it did the same thing for no reason. i think you get what you paid for!!!
Oct 20, 2005 | RCA RT2500 System
RCA RT2500 System Logo
131 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
