Question about Denon AVR-2802
Pc to denon av 2802
Hello... how do i hook up a computer to the denon in order to get sound. My audio card has composite cable, where in the denon should i hook it up to? i already have every other equipment hooked up and working perfectly.
Just need the pc working now to get audio.
thank you
    Problem Solver:
  • 8 Answers
You can use an auxiliary input on your Denon. What type of connection is available on the sound card? Some models have toslink while most have the mini-jacks which will require an adapter (mini-jack to RCA) which you can connect to the AUX input on your Denon. On the computer, make sure the LINE-OUT of the sound card is activated.
Posted on Feb 02, 2008
Denon AVR-2802 Optical Issue
If you look at page 16 of the user manual it tells you how to assign the devices to the optical connections. Once this is done it should work.
If you don't have the manual just type "denon avr 2802 manual" into Google and it will show a free PDF file of it. On my search it came up first!
Feb 09, 2018 | Denon AVR-2802
Trying to add Wii, but no video only sound.
The manual says you can get an optional Component Video cable (RVL-011) for the Wii. There is apparently one unused Component Input on theDenon where you could connect it. You would still have to use the Red/White analog audio.
The Yellow is for Composite Video only. It's lower quality and not compatible with Component Video (3-wire).
In the short term, why don't you just run the Wii's combined Composite video / analog audio cable to the provided Composite Inputs labeled DVD, VDP, TV/DBS, VCR-1 or VCR-2 on the Denon?
It would not be necessary to have BOTH Composite and Component video from any device, much less the Wii.
Ponder this, why do you need to run the video from anything to the Denon at all if your TV has mutliple video inputs? TV's specialize in video, theDenon specializes in audio. You can always extend the Red/White audio cables to reach the Denon.
May 06, 2010 | Denon AVR-2802
I have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Apr 13, 2010 | Denon AVR-2802
I am trying to connect my wii to my denon avr-2802 using the wii's composite cables. i get sound but no picture. help.
After connecting the Wii cables, connect a video cable to the "monitor out" connection to a compatible input on the TV.
Feb 15, 2010 | Denon AVR-2802
Hi, I have a denon 2802 av receiver. My Dolby decoder seems broken, the doby-display-indiactor is blinking as soon as a dolby signal is receiced. resettting doesn't help. DTS is still working. Anaybody...
The processor that creates the surround is all on 1 chip so sounds like a software issue.
Call Denon to see if they have a firmware update for your unit this usually is free and may fix the problem
Feb 13, 2010 | Denon AVR-2802
Hi, i have the Denon AVR-2802 reciver. My issue is when i plug my xbox into the dvd compontent inputs, i cant get any audio or video. I was working a few days ago, i had to disconnect the amp, when i...
Component inputs are for video only, and when connected through a receiver then the television also must have a video input coming to it from the video out from the receiver. If you want audio that will be a separate connection from the xbox to the receiver either by digital coaxial cable or optical cable, or composite.
Dec 15, 2009 | Denon AVR-2802
Denon AVR 2802
if the display did not lit and power indicator is flashing rapidly------you will have short circuit in speakers cables -----turn it off and remove short circuit cable-------or you have block in ventilation holes---------turn power off and leave it to cool down and remove anything block ventilation holes---and turn it on again after cooling---------another solution-------on screen display is set to off on system setup------turn it to on in system setup.
Aug 04, 2008 | Denon AVR-2802
DVI to RCA3 AV OUT
DVI to Composite Video (yellow) adapters are available in many online stores for mail order. You will need to get a separate mini-RCA jack to stereo RCA adapter to hook the audio output from the computer to the stereo audio (red and white) connections of the cable.
Search google for DVI to composite video adapter, and the mini-RCA adapter can be found at most home entertainment or electronics stores (Best Buy, Circuit City, etc)
Jun 10, 2008 | Dell XPS 200 PC Desktop
Denon AVR 2802 - Unit Turning Off
If DIGITAL sign blink, this mean DSP board is defective. It will cut the sound on the AMP section. DSp is maybe defective.
Jan 12, 2008 | Denon AVR-2802
Denon AVR-2802 Logo
263 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
