Question about Samsung DLP HL-P5663W 56" TV
Lost volume Not sure what happened. I was watching the TV and decided to change the channel. As soon as I did I lost volume. Returned to the previous channel to see if perhaps it was a fluk, but also no volume. There was no sound of something that would cause me to believe something blew. Referred to the manual but it didn't help. Not sure what to do.
    Problem Solver:
  • 10 Answers
Check the power amplifier IC at the audio section
Posted on Feb 01, 2008
I have lost the remote for my tv. How can I change from tv to video on the tv itself? I have tried hitting the source button then scrolling to video with the channel buttons but nothing happens
Unfortunately with most tv's today, you can't do much other than change channels or volume control without a remote.
Do you have an input button on the tv, if so, that will allow you to change from TV to video.
Jun 07, 2015 | Televison & Video
My emerson ls320em1 has good pic bt the volume goes up n down by it self
Does this happen while watching a program or just when changing channels? Most cable companies are notorious for not balancing their sound levels form channel to channel. Same applies to off air programs too Make sure the connecting cables have a good connection and are of high quality. Anything else is in the tv itself.
Jan 03, 2014 | Televison & Video
I have recently lost the sound on my 32 inch LCD tv
1.) Check its not muted/ the sound is all the way down
2.) If the TV has seperate speakers make sure they are plugged in to the main unit.
3.) If you are watching tv change the channels, if any channels have sound then the one you were watching has lost signal, try retuning.
4.) If all these have failed your TV may be on the way out :(
Mar 05, 2011 | Televison & Video
Ive had my vizio for 4 months and just recently the volume on the same 4 channels slowly decreases til you cant hear much. With a change of the channel or a commercial the volume returns. Recently moved to...
First - connect DVD player preferably to the same input (unless you are using RF connector) and make sure that same issue does happens while you are watching movies. If it does - main board in your TV have to be replaced. If it does not - it still cable signal problem.
Aug 11, 2010 | Vizio SV421XVT 42 in. LCD TV
Hello my mother's rca tv is stuck on channel 91. when i turn it on and use the channel keys on the set, they don't change the channel. i'm trying to get it on channel 3 so she can watch her cable.
Press Setup until you see AutoProgram... press Volume ... you will see the channels start to change. It will cycle to ch 62 or so, then go back and do the lower channels. as soon as it hits 3, quickly press Setup. it will stay on ch3, if not do it again. Once you get it on ch3, press setup until you see Channel Add/Del ... press Volume to add it. Press setup until screen is cleared. Ch /- should now toggle between 3(cable) and 91(a/v in)
May 17, 2010 | RCA Televison & Video
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Feb 22, 2008 | Televison & Video
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
