Philips 42PF7320A 42 in. HDTV Plasma Television
Problem for Philips 42PF7320A 42 in. HDTV Plasma Television
Philips 42 in. Plasma shut down
By shnawky on Feb 01, 2008
My wife was watching tv today and the screen started flashing colored blobs. No discernible picture was coming through. Can't open menus. After 10 seconds TV goes blank. Green front panel light goes off. Red panel light starts blinking (7 times...pause...7 times...). Have to unplug TV to get power fully off. Can't get picture back up. Audio was fine, but seems to be gone now as well...
HELP appreciated.
Comments:
Feb 01, 2008
- As I AV+ through to DVD, etc., the same problem. I disconnected all inputs (coax, Dish receiver vid and aud., side input DVD) just to see if I could get the menu up. No luck. Just the flashing pixel mix...
Same Problem
Mar 03, 2008
-   Had TV for 2 years with no issues then it just shut down.
It now displays the 7 red flashes on the front panel LED.
Tried unplugging for a day and the TV trys to power up but shuts down in about 10 seconds or less.
Prior to this occuring, the TV would have intermittent issues with not displaying the bottom portion of the screen for several weeks.
Anyone know what it costs to have the PSU replaced or if the part/board can just be bought for self-install ?-   myplasma
Mar 03, 2008
-   I am a Tech in NZ.This is a common failure of this model.The only solution, we are told, is to replace the PSU. If anyone has a better fix I'd love to know as these PCB's are very expensive. Apparently Samsung who make the boards do not supply any circuit information.-   Guest
Best Solution
posted on Feb 01, 2008
Helpful)
Longhorn_Fan
Rank: Wiz
Rating: 82%, 81 votes
The LED blinking 7 times is a code to tell the service tech what is wrong with the TV. From what I've read at other sites it sounds like there;s a good posibility that it is a power supply gone bad.
You probably should call a TV repair shop for assisitance.
Was this helpful?
Yes
No
Solution #2
posted on Apr 13, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
Solution #3
Somewhat Helpful)
djnick989
Rank: Wiz
Rating: 81%, 949 votes
did u cheak the input cables does it do it on dvd input as well as others ?
Was this helpful?
Yes
No
Solution #4
posted on Mar 02, 2008
Not Rated)
professorkev
Rank: Apprentice
Rating: 0%, 0 votes
I was watching tv with my philips plasma and then it shut itself off, as if I pushed the off button. I went up topthe tv and felt more heat than normal coming form the plasma. ANyway that was 2 weeks agaoi and to this day it does not power on, no light no NOTHING.
Any thoghts?
Was this helpful?
Yes
No
Popular Solutions for Philips 42PF7320A 42 in. HDTV
Questions and Unsolved Problems for Philips 42PF7320A 42 in. HDTV
Do you recommend Philips 42PF7320A 42 in. HDTV Plasma Television?
Answer
Answer
My philips plasma flattv randomly shut off today while i was watcing it. It just went black and the... (More)
Answer
42" philips plasma. black screen and 7 red flashes on the led
Answer
i have a Philips 42PF7320/A Flatscreen Plasma TV which shows red lines all across from left to... (More)
Answer
my 42" Philips plasma TV suddenly stopped coming on with a 4 red flash code replacing the green... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 42PF7320A 42 in. HDTV...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
