Question about Cisco 675 Router
Router cannot get IP with cisco 675 modem
I have a d-link di-524 wireless router that i am trying to install so i can have wireless internet in my house. currently my pc (winXP SP2) is connected to the internet thru a cisco 675 dsl modem. my isp uses dynamic IP and auto DNS. when i connect the pc to the router and the router to the modem, i can get to the web configuration for the router but i can't access the internet. in the status tab for the router under WAN it shows that my IP address is when i try to renew DHCP it times out.
DHCP server in the cisco 675 is enabled. i am looking at CBOS thru hyperterminal but i don't know what to do. i have tried cloning my pc's host name and MAC address but the router still cannot get an IP. i don't really understand this stuff, it's too much for me... help!
  • thomasjw76 Feb 01, 2008
    you had it right, brilliant. Once I found the commands for the Cisco so I could disable its dhcp your suggestion worked perfectly. all is now up and running as expected.
    many thanks!
  • Anonymous Mar 15, 2014
    unable to access the web site to update this router
  • 139 Answers
Do you know if your computer is using TCP/IP or PPPoE when connecting to the DSL modem? Check the Local Area Network settings on your PC ...if the PPPoE protocol is present, then it may be necessary to use PPPoE when connecting the wireless router to the dsl modem.
PPPoE = Point-to-Point-Protocol-over-Ethernet.
PPPoE configuration usually requires a username and password that has been provided by your ISP. Depending on the firmware version, your D-Link wireless router should automatically detect a PPPoE connection and prompt you for the username password. If it doesn't, you can set it manually through the web configuration screens.
Good luck...and I hope this is helpful!!
Posted on Feb 01, 2008
    Brigadier General:
  • 6,966 Answers
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
  • Louie  Role
    Louie Role Feb 01, 2008
    Hi again,
    Missed mentioning, you may need to refresh/repair Network settings of all PCs to use the DHCP server of the DLink.
  • Louie  Role
    Hi again,
    Glad to be of assistance and appreciate the rating.
My modem is sagem i cannot put security code for wireless connectivity
The wireless security is being set on the router's admin page and not on the modem... by default the IP address of the router is, you may access it via your Internet browser....
Mar 12, 2010 | D-Link AirPlus DI-524 Wireless Router
Wireless repeater
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
-Open the web browser
-Type in the IP Address of
the Router (
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
Home > Wizard
Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuration change.
Home > Wireless
SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
Cannot connect to the internet
Reboot your modem, then reboot your new router.
The rebooting is an essential process of installing a new piece of hardware to a modem.
When your modem boots up it leases an IP Address to the MAC Address of the first connected piece of hardware (router in your case). If you switch hardware without rebooting, your modem will not recognize the new piece of hardware because it has a different MAC Address. Every piece of hardware has its own MAC Address, unless it has been cloned.
Feb 25, 2010 | D-Link AirPlus DI-524 Wireless Router
Dlink router is not connecting to the internet
Check the lights on the router to make sure both out going and incoming are on.
Manual link below in case that helps
If not both on contact broadband supplier as IP for router may have been "altered" and will need resetting their end.
Not unknown for an outage to be proceeded by a "spike" which can blow unprotected items.
Jan 24, 2010 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Ethernet connection of DI-524 does not work
You have to make the Ip changes on the laptop not on the modem.
You said you have internet acces on one computer. Then use that computer to find out the exact IP address used by the modem.
On the laptop use the exact same numbers, (IP, Sub mask, Gateway, Primary DNS)
and chek if it works.
If you want to have both computers on the Internet, simply change the last number on the IP address ONLY.
Please don't forget to rate this answer if it helps
Sep 22, 2009 | D-Link AirPlus DI-524 Wireless Router
My D 502T Adsl+2 will connect but when I try to
First of all, what IP address does the 502 give you when you plug into it alone? Do an IPCONFIG from DOS and note the numbers.
Now, what is the default IP of the 524. Is it the same as the 502?
If it is, change your 524's IP to something else, like
If it isn't, please post back what your IP configuration is and what the link is, DSL,Cable Modem, PPPoE, or DHCP either fixed or variable.
Apr 01, 2009 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of, and the DLINK IP uses Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Connection Problem
insatll your drver cd of router if u have connted with a usb cable
then after configar your router
the router defot ip is
type in your web page address bar
the user name is admin & pass: admin
just login & configer
& enjoy
Mar 24, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Cisco 675 Router Logo
759 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
