Question about Panasonic (KX-TDA200)
Tda-30 phone system
Refitted phone socket on wall and now phone doesnt work that is on tda-30 pabx
  • Michael Lucas
    Michael Lucas May 11, 2010
    Are you getting a dial tone. If not then wrong pair of wires used.
    Problem Solver:
  • 19 Answers
It does not require the inner pair to function unless it is an analog phone. It uses the out pair of wire or the black yellow if you are using phone cables. To make sure hook up both sets of wires and make sure you cord form the wall to the jack as 4 wires also.
Posted on Apr 15, 2009
Uniden troubleshooting
was the old phone connected to a Private Automatic Branch Exchange P.A.B.X like for example a comander system if so the new phone would have to be a PABX type phone extention type. I suspect the Uniden phone is not compatible with the PABX extension socket.
http://www.excitingip.net/291/ata-analog-telephony-adapter/
http://www.kosmaz.com/ata.htm
http://www.cisco.com/c/en/us/products/collateral/unified-communications/ata-186-analog-telephone-adaptor/product_data_sheet09186a008007cd72.html
I do not know what phone system you are using you might want to find out the model number of your PBX device and research if it uses VOIP = I can only guess that this is the situation
Sep 01, 2014 | Radio Communications
How do I update the time on the panasonic kx-t7730
that is not pssible to set from telephone
there is a PABX device (panasonic kx-tes824 ) fixed in wall
from that PABX check 101 extension number (maybe 10, wich phone connected jack1 )
from there is only you can program
Please let me know this useful
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
Wont hook to a second wireless phone
Was it supposed to? A 7630 XDP only works if there is hardware behind it. That means the first 4 ports only of a TDA-15/30/50 or a combo card the 8-port card in a TDA-100 or greater. The DXDP only feeds a comparable 76xx digital phone.
Carl
Dec 24, 2010 | Panasonic KX-T7630 Corded Phone
I have a phone system in my house using the KX-T7633 model corded phones. I want to plug in a cordless phone in the back of the KX-T7633 so that I can be cordless, but when I do I can not get a dial tone...
In a TDA-30/50 there are FOUR super hybrid ports, the first 4 on the cabinet. In a TDA 100/200/600, there are NONE. Which one do you have and is your extension 101-104? If not, it won't work. You can probably wire an analog port to the first pair and use the same cable, but it will never merge with the digital set.
Carl
Aug 24, 2010 | Panasonic KX-T7633 Corded Phone
DOESNT TURN ON
Does it show any sign of life when powered on. Some light coming on, or some sound being emanated.There could be a number of reasons for the to Not come on. 1. The wall socket may not have power. (Unlikely). 2. The power cord may be defective. (Unlikely). 3. The power on switch may be defective. (Most likely). 4. The TV may be dead. (Unlikely). Unlikely or otherwise, you must check all the reasons.
Aug 23, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
I need new panasonic kx-tda 600 pabx software?
KX-TDA100 Maintenance console found at www.wanetelecoms.com
KX-TDA200 Maintenance console found at www.wanetelecoms.com
KX-TDA50G Maintenance console found at www.wanetelecoms.com
Panasonic Unified Maintenance console Version 7.3 found at www.wanetelecoms.com
Mar 04, 2010 | Panasonic (KX-TDA0104) (KXTDA0104) Power...
Interconecting 2 Panasonic KX-TDA 200 & KX-TDA600
You are asking for some very advanced setup features, as far as connecting them you need the IPGateway cards. They are cat5 cards that will do the trick. However programming the setup to do what you want will be VERY time consuming and not to easy to walk someone through. On-site tech is highly recommended for that much programming and work.
Feb 24, 2009 | Panasonic KX-TDA0410 (KXTDA0410) Network...
Switchboard PABX purchase
If you need 8x30, you start with a minimum of TDA-100. It grows to 96 ports and you would start with 8 lines and 32 digital ports.
Your phones become KXT-7633's, not the 7731's. On this side of the pond, it costs about $20 more per phone, but you gain the use of 12 extra buttons, 3 line display, and more features.
Your Panasonic TDA/TDE dealer can guide you.
Carl
Jan 15, 2009 | Panasonic KX-T7730 Corded Phone
I have a NEC NDK 9000 PABX fault after relocating phone lines,1 extension is not working and the other 2 are, I have noticed there is a red light flashing on one of the cards and am assuming there is a...
Each PABX or telephone system needs its own driver as each system has its own output format for the SMDR port. Therefore the MonTel system must have a suitable driver (technically a receiver) for each type of PABX that it can support.
http://www.netwiz.com.au/appnotes/1872.htm
May 10, 2008 | Lands Phones
Problem in PBX kX-TDA 100
dear sir can i get softwear version 5 for tda 100 pbx exchange panasonic
Apr 11, 2008 | Panasonic (KX-TDA0104) (KXTDA0104) Power...
Panasonic (KX-TDA200) Logo
171 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
