Question about Vacuums
KIRBY G4 FAN ASSEMBLY ORDER
MY KIRBY G4 FAN WAS BROKEN, I JUST PURCHASE A NEW G4 FAN KIT. This kit includes a new fan, new pulley, new spacer, new washer, and a new gasket. THE ORIGINAL ONE WAS A ONE PIECE METAL FAN.
I NEED HELP TO ASSEMBLE THE G4 FAN KIT IN THE RIGHT ORDER.
THANKS IN ADVANCE FOR YOUR ASSISTANCE.
SINCERELY,
LOUISYF@YAHOO.COM
    President:
  • 1,673 Answers
First put the gasket on the spacer, thin end to to out, push it down all the way on the motor shaft, then put the nylon washer on, then the fan, metal washer and then the pulley, just snug it, (don't tighten too much just beyond hand tightening). Put the casing, top and handle back on.
Posted on Feb 05, 2008
Looking for a Kirby G4 impeller?
Hi There. Here's the Impeller Blad, or Fan assembly for your Kirby G4. Hope this helped you.
Please leave feedback or rate the repair helpful if this answered your question, thanks!
Kirby Impeller Blad Assembly
Thanks so much,
Chris Jones
GoVacuum.com
Dec 29, 2010 | Kirby G4 Bagged Upright Vacuum
I need a manuel to replace a broken fan on my g4 kriby
We have actually recorded a very informative do it your self video on how to replace the fan on a Kirby Generation upright.
The video is a two part video, but this explains step by step how to remove the old fan, and put the new one on.
If you need to purchase a new fan assembly, here's a link to the Fan assembly for your Kirby G4. Unfortunately you may only purchase them as a complete assembly:
Genuine Kirby Vacuum Fan. Kirby Part # 119096S
Here's the videos showing how to replace the fan:
Part 1:
Part 2:
Hopefully this helps you with your problem! If this did help, please be so kind and rate the repair, or leave feedback for me. This is very appreciated by the Fixya community when someone is able to answer your question, and assures that experts continue to answer free questions, instead of just the premium paid questions.
Thanks again!
Chris Jones
GoVacuum.com
May 15, 2010 | Kirby G4 Bagged Upright Vacuum
The green light is not coming on and kirby is not sucking
HI There,
When the green lights do not come on when vacuuming with a Kirby, this indicates that your belt has either broken or fallen off. There is a magnet on the beater bar that activates the LED green light when it's spinning.
Here's a helpful video tutorial that we recorded, that will show you how to replace the belt, as well as perform basic maintenance on your roller brush to prolong the life of your belt as long as possible.
Video Repair on How To Check The Belt on a Kirby Generation G4:
I hope this was helpful! If you have any follow up questions, please feel free to use the comment field here on Fixya.
If you need to purchase a new roller brush, or belt for your Kirby G4, here are direct links to those parts on our website:
Kirby G4 Roller Brush Assembly:
http://www.govacuum.com/kir108.html
Kirby G4 Agitator Belt:
http://www.govacuum.com/kir143.html
If this repair was helpful to you, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by the Fixya community when someone answers your questions.
Thanks again,
Chris Jones
GoVacuum.com
May 14, 2010 | Kirby G4 Bagged Upright Vacuum
Th end of the shaft that come from the motor is worn out, and won't hold the belt well. How do I change it?
Thanks for the clarification. I have never seen this problem previously in a Kirby. I wonder if the belt keeps sliding off because it's been stretched out? After about 1-2 years, the belts on the Kirby will stretch out to a point where there can possibly slide off the motor shaft. Have you tried just replacing the belt on the unit first?
If you're sure that it's not the belt that may be stretched out, and you'd like to replace the motor shaft, you certainly may do this. The only problem with this is the motor shaft is not sold by itself as a separate part. The only way to purchase this motor shaft is to purchase the entire fan assembly, which includes a new fan, and the hardware necessary on the fan assembly.
Here's a parts diagram that shows you the motor shaft is sold only in a completely assembly:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/kirby-generation-parts-diagram.pdf
If you haven't already purchased the motor shaft, here's a direct link to the motor shaft and fan assembly on our website:
Kirby Generation Fan Assembly With Motor Shaft and Hardware
In terms of installing it, we've actually recorded a video repair on how to replace the fan assembly, which involves removing the motor shaft in order to get the fan off. Since you have to purchase the fan assembly anyways in order get the motor shaft, you may want to go ahead and replace your fan assembly at this time also. Even though your fan may not be broken, on Kirby's the fans can become coated with dirt and fine dust, which can sometimes lead to the Kirby exhausting a bad smell. If you'd rather not replace the fan, you may remove the motor shaft without disassembling the entire machine, you'll just need to secure the fan somehow so that the fan doesn't spin while you're using a nail to turn the motor shaft off.
Anyways, here's the video repair that we recorded. I hope that this helps you. If you found this helpful, please kindly rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair. This is really what keeps Fixya repair professionals continue to give free repairs online.
Here's Part 1 of the video:
Here's Part 2 on Replacing the motor shaft and fan:
If you have any follow up questions, I'd be more then happy to answer them for you, please just add another comment here on the repair page, and I'll be more then happy to answer any follow up questions that you have. Thanks again for rating the repair, I greatly appreciate this.
Chris Jones
GoVacuum.com
Apr 15, 2010 | Kirby G5 Bagged Upright Vacuum
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Broken Lexan fan needs to be replaced
It is similar to the G4 but without the tech drive so is easier.
Apr 30, 2009 | Kirby Heritage II Vacuum
Need new brush for g4 and new belts
Kirby Vacuums
Can you help me find a agent where I can buy parts for my Kirby, I live in Melbourne.
If the customer lives in the United States the customer can purchase the Genuine Kirby Parts from any Genuine Kirby Dealer including the fan, bags, belts brushroll, etc., or if you need help call a Kirby dealer in the yellow pages under vacuums or call 1-800-328-9430 to have them shipped to your location. Even if it is Melbourne, Australia – they can ship the items to you using a credit card to your location.
http://www.avacorp.com/
Apr 06, 2008 | Kirby Heritage II Vacuum
Fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
117 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
