Question about RCA P52926 52" Rear Projection Television
Problem With Colors
RCA 92526 Rear projection 52"
The Colors on my TV went out today, they are all offset and overlapping, and the middle of the tv is bowing towards the middle, top and bottom... makes it compeletly unwatchable....
  • PUNKO1 Feb 15, 2008
    RCA HD52W59 COLOR AND HOUR GLASS PICTURE
  • 579 Answers
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests.
If this doesn't work, the modules need replacing.
Best of luck, hope ya fix it.
Posted on Feb 01, 2008
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
Colors arched and overlapping
if the option for convergence is still listed under the setting section of the on screen menu, then you need a convergence power supply board. If the convergence option is missing from the menu you need the ITC222 convergence missing repair kit. You can get either one at the following link they include instructions for the repair.
http://www.tvrepairworld.com/
Jul 13, 2009 | RCA R52WM24 52" HDTV Projection Television
52"projection tv colors overlap
Your convergence is bad. If after trying the Auto Convergence option on the TV it doesn't correct itself, you can try manually adjusting the convergence Here is a link to perform a manual convergence on your set. Good luck!
Greg
http://www.ehow.com/how_2034880_perform-convergence--tv.html
May 23, 2009 | RCA Televison & Video
Overlaping colors
NO, does not lamp problem.
If its rear projection TV then its convergence our ICs failure problem and need to be replaced these ICs.
Let me know exact model and brand of TV for more info.
Apr 30, 2009 | Sony KP-46WT500 46" Rear Projection...
Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Apr 28, 2009 | RCA D52W19 52" Rear Projection Television
52" RCA Projection TV
This is an indicates what is know as convergence problem...this could also be what is know as deflection problem... have a technician look at it.
Oct 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W59 REAR PROJECTION
there should only be three colors.. can they be aligned?
Sep 16, 2007 | RCA HD52W59 HDTV Projection Television
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
