Question about Garmin StreetPilot c340 GPS Receiver
Garmin is frozen on, and will not respond.
While traveling, my Garmin has frozen. It is still on, but will not allow me to turn it on or off. I tried unpluging it, and it stays on the same screen. It has not changed at all. It does not respond to any touch on the screen. It is just over a year old. I have never up dated any maps or anything. Please help.
  • 2 more comments
  • RenatoLunnon Apr 28, 2008
    I was downloading an update.  As the unit we restarting after the download, the device became unreadable by Windows.  Now all that happens on the unit is the 'StreetPilot' start up screen comes up.  I tried resetting and powering down, but nothing.
  • jabell May 28, 2008
    I have a garmin c 340 and it is frozen on, cannot get the face plate off??? to reset??
  • vaporland Jun 07, 2008
    i have the exact same problem - resetting does not fix it - i guess it's hosed
  • jkrulder Jul 12, 2008
    same problem - don't try unscrewing the only visible bolt - it doesn't work - Help!
  • 504 Answers
Have you tried resetting the unit? Remove the faceplate and press the reset button on the right side of the unit. This may help.
Posted on Feb 07, 2008
My Garmin 255W froze up in the ON mode. Nothing moved and I could not turn it off. With nothing else to do I let the battery run down. When the screen went blank I plugged it into the car and turned it on and it came alive as if nothing had ever happened except it skipped the previous 200 miles. There was a low battery warning but that was to be expected.
Posted on Jul 05, 2010
I have a Garmin 1300 and it does not boot. I get a splash screen and everything freezes up. I have tried to reset it. I have tried to restart it with holding the button down. Etc, etc. I have tried to start it with a USB cable hooked to the computer. All the usual tries. Nothing works. Garmin's site does not talk about this problem. I wonder why? Maybe I am the only one having this problem or maybe not? What should I do?'
Thanks
Michael
Posted on Oct 25, 2009
Kevin,
Great advice, thanks!
Posted on Mar 07, 2008
Garmin 1450 nuvi screen stuck on garmin
Call Garmin support as they can usually try to rebuild the Software that is frozen. figure on a 15-30 min call to them. Ask for the Software team that can remote into your computer and do this for you.
Mar 22, 2015 | Garmin GPS
Garmin nuvi 1450 cannot turn off,is frozen. hav been traveling for 2 days so has been plugged in most of the time
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin GPS
Can't get past the WARNING/Agree screen
Try re-setting it. 1 -hold thumb is lower right corner - turn on unit - keep pressure on - as shown in pic 2-push YES 9124cfe.jpg
May 03, 2010 | Garmin nuvi 255W GPS Receiver
Touchscreen not responding.
There are three levels of fixes, please try them in order:
1. Reset the GPS using the Reset button, on the back, just under the Antenna Hinge. Resetting will turn off the GPS, and then turn it back on, if connected to power. Test, if fixed, great, otherwise, go to fix 2.
2. Turn the power off, then press and hold the powerbutton for up to 2 minutes. The GPS will turn on, and display a "PreBoot Mode" message. When that message disappears, and the screen calibration screen appears, follow the on-screen instructions, and you are fixed. If you still cannot use the touch screen, repeat fixes 1 and 2 several times, just to be sure., then go to fix 3
3. The touch-screen glass has probably broken or lost its connection with the GPX motherboard. You can order new touch screen glass on the web and install yourself, if you are techy in nature, otherwise do a search for "garmin nuvi 660 repair" and choose your service.
Jun 19, 2009 | Garmin nuvi 250W GPS Receiver
The garmin is on but frozen
Look near the SN # and press the reset button.
or
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Mar 27, 2009 | Garmin zumo 450 GPS Receiver
My gps is frozen and wont turn off or respond
took face plate off and reset button on left fixed it Thanks
Aug 27, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT 320
To unlock a “frozen unit,
1. power it off
2. Remove the face plate, Gently pry on the face plane. In the center top edge (under the Garmin logo) you’ll see a small notch.
3. on the right side of the unit, press the reset button.
4. replace the face plate
5. Power it back up.
The unit should restart normally.
Mar 21, 2008 | GPS
Garmin StreetPilot c340 GPS Receiver Logo
5,264 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
