Question about Toshiba Satellite M45-S265 Notebook
Laptop router interface
I have a Netgear router, 54 Mbps WRG614 and a Toshiba laptop Satellite M45-S359. Problem is that I connect easily at 54Mbps and sometimes after an hour or so the connection speed changes to a lower connection speeds all the way down to 1Mbps. It may go back up after a random amount of time or if I reboot it then immediately goes back to 54Mbps and works ok for a while and then it drops down again. I know it is not the router because I have two different Netgear routers (same model numbers) and the problem is idential with either router. I also have contacted Netgear and have changed the frequencies and still have the problem.
I suspect it is something with the laptop!
Can you help?
    Brigadier General:
  • 6,966 Answers
Assuming that it is a laptop issue, pls verify that in your Device Manager,/Wireless Adapter/Properties/ that:
1. Advanced - All Property Setting should be "Not Present" except for the Authentication if you use WEP or security key;
2. Power Management - uncheck "Allow Computer to turn off..."
Pls log down your current settings before changing so as to have a restore basis if things don't work out.
There might also be some other settings such as transmit power that could be changed to "always high" or something like that.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
Netgear N300 is slowing down my internet connection
The router limits the data speed to the wireless reception.
802.11 G speed (maximum) is 54Mbps.
Jul 17, 2013 | NetGear N300 Wireless Router
Toshiba Satellite M45 S359.
The actual switch is rare to go, the DC jack in the laptop is more likely the issue and will require a complete tear down to access.
May 29, 2012 | Toshiba Satellite M45-S359 Notebook
NetGear wireless router WGR614 v6 runs with speed 1 0 mbps instead of 54 mbps
how far away are you from your wireless router when your getting 10 mbps?
Please note that wireless will not guarantee speeds of 54 mbps.
It will dramatically decrease the farther away you or how much interference there is between your laptop and router.
Also check if your wireless router is set to 802.11 G mode. if you have any devices that only support 802.11B you will only get speeds up to 11mbps compared to G at 54mbps
Mar 13, 2011 | Computers & Internet
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
Netgear WNDR3300 - will connect only on the wireless -g not -n. I cannot see the -n SSID on my laptop. I can see around 10 other networks on -n (from the building that I live on) so it's not the laptop....
your laptop should support n standard... and n and g are the standards... so you wont face any change in ssid...
g communicates at 54mbps, while n communicates at 150+mbps g standard card can communicate with n router at g(54mbps) speed...
Sep 26, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
100mbps on my house computer but only 54 on my laptop
100mbps is just the maximum speed capacity that can be used and depends on the speed that you subscribed so it doesn't mean you'll get a sharp 100 mbps on that.
Mar 31, 2010 | Toshiba Satellite M55-S331 Notebook
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
NetGear WPN824
No llegas a esa velocidad por q no tienes una tarjeta inalambrica para dicho proposito
tienes q compar una tarjeta de netgear para q puedas aprovechar los beneficios de tener una tranferencia d datos mas rapida
Yo compre esta cosa pensando q la tarjeta prefabricada en mi laptop podria correr mas de 54mbps pero ese no es el caso...tienes q comprar la tarjeta d netgear awebo.
Jul 15, 2008 | NetGear RangeMax WPN824 Wireless Router...
Router does NOt connect
why not you can connect the internet. first you tell me how much mbps now you using ?
Jun 12, 2008 | NetGear WGR614 Wireless Router
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
