LAN problem hi good AM my name is eufred my problem is lan connection because i install hub for networking of my two pc my one pc have a good connection and my pc 2 is poor connestion
  • 1 more comment
  • rhed_360
    rhed_360 Feb 04, 2008
    ok thanks
  • rhed_360
    hi
    paano poh ba mag download ng mobo driver model 848P poh ang mobo q chipset intel thanks poh
  • rhed_360
    rhed_360 Feb 09, 2008
    hi gud am poh,
    my probema poh ako kc ang hard drive ko poh na western digital ay ayaw na mag boot and may 2nug poh akong naririnig sa loob sa plagay nyo poh anu kaya problema nun? sira nba un? thanks poh....
    Problem Solver:
  • 4 Answers
've never checks his cable connection yet .... his own question I had it happen before when I was his connection cable rates proved her wrong cable
Posted on Jun 02, 2010
    Problem Solver:
  • 42 Answers
Hi!good pm...hope this will help...
sometimes it depends on the speed of the pc or on your internet service provider or in the hub itself...try to read the specs of your hub and see how it works if it has a multiple connection...
Posted on Feb 01, 2008
Network cable connection not recognized
Make sure the LAN driver is installed and working.
The LAN cable maybe faulty, try another one.
If the LAN cable is a red one then it most likely a crossover LAN cable. This cable is used to connect two computers together without a LAN hub or router.
Sep 21, 2012 | Dell XPS M1330 Laptop Computer PC...
I cant connect laptop with ethernet cable
I assume the LAN adapter driver is installed and is working properly.
The LAN cable maybe faulty.
If the LAN cable is colored red then it is a crossover LAN cable and this is a special LAN cable for connecting two computers together without a network hub or router.
Try a another LAN cable..
May 13, 2012 | ASUS Computers & Internet
Is it possible to installthe lan item on computer to connect to a home network? is software available to download
Hi Margaret,
The lan item to which you refer must be a phisical network adapter. This may be a
device that must be installed inside the CPU, or
either an external adapter with USB interface.
These devices come with their respective
drivers.
Furthermore, to connect multiple PCs you need to buy a HUB or a Wi-Fi Router, and each PC must have its network adapter installed and configured.
Mar 20, 2011 | Computers & Internet
Reconecting the cables to the hub does not make a network
Not necessarily! As long as a lan cable is connected on the wan port of your hub and the other end goes directly to the modem, the connection is correct. The remaining port will be left for the lan cables of the computers. No orders needed. Just make sure that lan cables was properly seated on the port. The LED blinking in the hub will tell you if its working or communicating with your computer. Find it, when the LED is not lit or blinking, the lan cable is not connected properly on the hub (or the other end of the lan cable is disconnected from the lan card of the computers).
If all cables are connected properly and still cannot connect to the network, you may need to refresh the name of the workgroup on the computers that cannot connect on the network,
How? Right click on My Computer.
Select Computer Name
Click Change to change the name of the workgroup that is being use by other computer. Delete the old name if the same and retype.
Restart the computer and try to connect using network neighborhood.
Jul 07, 2010 | D-Link DSH 16 (DSH-16) Networking Hub
Sir can i connect two pcs one desktop and other laptop for sharing files bw the two and playing games bw them
There are a couple of ways you can network two computers together.
Each computer must have a network card installed together with the LAN card drivers. The two computers needs to be connected to a network hub and these computers need to be set up on the same workgroup name.
Using a network hub will allow more the two computers to be connected to a network and the number of computers that can be installed on this network depends upon the number of available ports on the network hub.
You can use a Crossover LAN cable to connect the two computers together and you won't need a network hub.
To information and how to setup a home network, please click on this link -
Home Network Guide, routers, print servers etc.
http://sites.google.com/site/networkguidedemo/home
Jun 20, 2010 | Computers & Internet
Cannot view my client in handycafe
Check if the LAN cables are connected properly, make sure that client PC's have handycafe client installed and connected to the hub/switch with the server PC.
In some cases wherein the server has two LAN Cards installed, make sure to choose the LAN Card which is connected to the hub/switch where the client PC's are also connected during the initial start-up of the Handycafe software.
Note: Check if the hub/switch or router (whichever you're using) does not have a problem.
Nov 05, 2009 | Computers & Internet
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Sir i we are 2 friend connected with LAN hub we want to connect via LAN. i want LAN setup between us
yes for this you both have to set workgroup name same .first connect the LAN cable to lan ports of yours...then in Network setting give manual ip addreess as 192.168.1.1 in one computer and in other as 192.168.1.2 (subnet mask would be same) .then u bath can access each other computer by sharing folder....
but you have to disbale windows firewalll
Dec 09, 2008 | Microsoft Windows XP Professional With...
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Pano mgnetwork?
gud pm keanne...hmmm here's my suggestion:
1st u need to buy 8-Port Hub/Switch
NIC or LAN Card
7 pcs UTP Wire w/ RJ45 Jack on both end (depende sa haba)
Then connect smartbro to the CPU (Built-in LAN)
Connect 8-Port Hub/Switch to the CPU (LAN Card)
Install Hub/Switch Driver (If Needed)
Connect the 6 PC to the Hub/Switch
Setup your network using Network Wizard (Control Panel)
goodluck...
Jan 29, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
272 people viewed this question
Alun Cox
David Payne
David Payne
