Question about Sony KP-53HS10 TV
No video - Blinking code 5
Hi - My seven year old 53HS10 went blank the other day - that is - no video, but audio is fine. The red light blinks five times after about 30 seconds. According to the service manual, this indicates a video board problem. Any chance of repairing this fault inexpensively?!
Yes im a tech unknown business i cant say what business or my name could lose my job but her you go, Fix the blinking light code 5 blinks turn down your picture vivid and your contrast ive makde plent of money fixing this issue for the company.
Posted on Mar 02, 2008
5 time blinking Sony Trinitron (Flat Panel) tv
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
To get more details, http://electronicshelponline.blogspot.com/
Blinking codes and details to Sony Trinitron TVs are given in detail.
Nov 15, 2013 | Sony Televison & Video
Blinking red light pioneer plasma
blinking light indicates that there is a fault with your tv , how many blinks does it do as this will be a code as for what is the problem , and how old is the tv and is it used alot through the whole day , also please list the model number of the tv you can locate it on the back of the set
Nov 03, 2013 | Audio Players & Recorders
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Sony Trinitron, KV-36XBR400 standby blinking light cannot power on. test it three times. first time, blinking 7 times, second and third time, blinking 5 times. bought it second hand two weeks ago...
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33kV and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Feb 23, 2018 | Televison & Video
I have a Sony KF 50 WE 610 projection screen TV. It has worked perfectly since I bought it six or seven years ago. This morning I turned it on and the sound came on for a second, but then the sound went...
Hello
Five consicutive blinks at a time and the stops and again blinks five; is its self diagonosis procedure. All modern Sony sets has this function included in its circuits. If the system control IC inside it detect any fatal fault inside its circuits system, it will give a signal to its power control unit to shut it down its high voltage outputs to protect the other components from further damage. In your set; as Sony describes; I quotes:-
  • Actually the components marked in numberes will not be the same as in your TV. But the fault will it be.
    If you have enough knoledge in electronics and have a concept of soldering and have a good quality multimeter; youreself can do this work by home. OK
    Mar 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
    My Sony tv screen blinks off and on and timer/standby blinks 5
    Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
    Feb 26, 2010 | Sony KP-53HS10 TV
    No Picture or sound, red standby light blinks six times
    Sorry for how long it is but you should be able to find what is wrong in this guide
    If you have any questions please dont hesitate to ask
    ONE Blink--- not used for the self-diagnosis
    TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
    THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
    supply circuit, check T603 and R672.
    FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
    horizontal line then the video signal muted. Check IC1509, Q1505
    FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
    board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
    SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
    function immediately. Check C515 & 516 and the jungle IC, IC206.
    SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
    EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
    blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
    Intermittent problems ?? This is a great feature. You can also bring up
    these fault codes ON-SCREEN to see a list of the problem numbers with the
    abbreviation of the problem and the number of times this problem has
    occurred. This is slightly different than entering the service mode. To see the
    diagnostic screen, Press the following buttons:
    Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
    a screen with a list of the problems and number of times they have occurred.
    Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
    We have repeated them in parentheses in the text for the "Blinks" described
    above so you can correlate between the diagnostic screen and the blink
    codes.
    So, now that you know about these self-diagnostics, how do you use them?
    Say that you have a set with a black screen. You see that the LED is blinking
    4 times....This would tell you that you have no vertical and that is why the
    video is muted. If it was blinking 6 times, you would know that you have a
    horizontal fault.
    It's not a sure cure, but it's a little better than a poke in the eye with a sharp
    stick.
    IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
    next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
    everything to the factory preset condition.
    Oct 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    KP-53HS10 has a blinking red light on
    Try getting a new power supply. Replacement SOny flyback 859882800. That part costs $18 and would be the most inexpensive solution. Unfortunately your probably gonna have to do it yourself unless you want to pay huge handling/service fees. Just google the part number and it should come up. Part# : 8-598-828-00
    SONY FLYBACK 8-598-828-00
    Dec 19, 2007 | Sony KP-53HS10 TV
    Sony KP-53HS10
    I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
    Nov 21, 2007 | Sony KP-53HS10 TV
    Sony KP-53HS10 TV Logo
    202 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
