TV SAMSUNG 61 IN. HLN617W
MY TV LOSS THE IMAGE AND I BUY THE LAMP BUT
NOW AFTER ONE HOUR TV IS TURN OFF WHY?? AND THE LIGHT INFRONT IS RELAMPING ARE GREEN.
HELP! PLEASE.
ATTE: ANGY
  • 87 Answers
Probably COLOR WHEEL bp96-00250A. It also could be a DMD board which is very expensive
Posted on Feb 01, 2008
  • 579 Answers
Sounds like it is overheating. It has a sensor that monitors light engine temp and causes a shutdown. Possible causes are:
- dirty ventilation fan filters.
- cheap lamp that makes too much heat
- faulty temp sensor (I don't think this model is known for this)
Samsung hln617w TV Dlp lamp won't turn on already replaced lamp, ballast, color wheel
It sounds like the main power supply has a bad capacitor. its a typical issue with a lot of electronic. look on the main power board that the outlet cord comes in to the TV and check all the cylindrical components for swelling, leakage, or singe makes.
Dec 13, 2013 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W No Sound. As I turn on the TV, the speakers give off a "sputtering" noise that can barely be heard. After a while the speakers come on. But, what used to take five minutes (2...
Red light comes on but then the tv is playing but after about 3 hours it just goes out but I can still hear the sound then if I go back after about 4 to 5 hours if I turn it on it plays no problem. Now the lamp just went. I think before replacing the lamp maybe I should replace cooling fan also.
Jun 07, 2011 | Samsung HLN617W 61" Rear Projection HDTV
New lamp, new color wheel installed successfully.. tv powers on for about two minutes and powers off, all fans have power, color wheel has power, no power to the lamp? fan on the lamp power supply has...
Powers on and image or no image ? makes a difference. honestly these tvs are prone to many problems that even a trained tech. would have difficulty solving. best to find a reputable company.
Aug 18, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Apr 08, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My HLN617W dlp will turn on with no picture (sound is OK), then will seem to turn off, then back on again without me doing anything. After this ritual being repeated, the lamp and power lights will start...
The lamp is finished. Order a new lamp using the code on the side of the TV. Remove the lamp door on the back of the TV (4 screws) and then remove the lamp (1 screw). Have a look at the lamp... is it damaged? See my tips & tricks if you want to learn more about the lamp.
Mar 18, 2010 | Samsung HLN617W 61" Rear Projection HDTV
Samsung hln617w non power up
Most of the time when these sets won't turn off it's caused by the DMD but check the color wheel connectors first, especially the flat ribbon cable. Make sure it's in the connector in the correct direction, only has contacts on one side and make sure the ribbon is not torn.
Mar 03, 2009 | Samsung HLN617W 61" Rear Projection HDTV
No picture but sound once it goes off there is 3 blinking lights
Most likely for this symptom is the lamp. If you'd like you could sit behind the set and have someone turn it on, you should hear the color wheel spin up and then you should hear the ballast try to fire the lamp, it makes a small arcing sound. If the lamp doesn't light the process starts over again.
Jan 30, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Hello
Problems with the lamp door detector switch. Try jumping out this switch and running it for a while. The switch is the small switch with the blue rocker arm activated by the tab on the lamp door panel.
Jan 31, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Samsung 61" HDT5087S/HL
How old is the unit?
ever replaced the lamp?
Sounds like a major power supply failure
Hope you are under warranty
Samsung has lots of problems with this technology
Here is their phone for executive customer relations: 1-800-522-7341
Dec 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
