Dead peavey supreme XL amp head
My friend gave me a peavey supreme head that didn't work, so i offered to take it hoping it would be something really easy that i could fix. i plugged it in to an outlet hit the switch, nothing, the led "indicator" didn't turn on. so i opened it up, checked the fuse, good, checked for any frayed wires, nope, checked for any burned or suspicious looking components and circuit board, also good. i haven't gone any further because i don't know if i want to dedicate my time. i would like to test the transformer but i don't know how. i have a good feeling it is a power supply problem, i was wondering if any anyone has ever had this problem or if anyone knows any test points that i could measure with my multimeter ?
It's an amplifing unit, it has no built in speakers, but the led indicator doesn't turn on which leads me to believe their is no power flowing through the circuit. Theres no tubes, it's a solid state amplifier (transistor).
Posted on Feb 01, 2008
    Sergeant:
    Champion:
  • 209 Answers
I'm not a pro on amps but I have a Peavey Rage 158 amp, I'd suggest seeing if the speaker itself still works by directly connecting a source onto the speaker[take the wires off and hook it up to a source].
Try turning it on and checking the wattage going to the speaker wire, then follow the wire back and check the big coil with copper wire among other things.
A common problem with old amps are the tubes, check the tubes to see if they are burnt out [google it if you need a guide]
then check on ebay or maybe an electronic/guitar store.
If that didn't help, reply with more details
Good luck.
[If you don't want it ill take it off of you for $20 :p ]
Buy a different amp
Posted on Apr 06, 2008
Buy a different amp
I have a HD 203 .. the right side speaker is not giving any output , the left is still working though...so do i have to change the speaker or the wire's or it useless and i have 2 through them awa
have a friend come over with their phones and plug in. if the same problem persists its the amp and it blew that channel. no problems then get new phones save old ones for parts.
Sep 16, 2012 | Sennheiser HD203 Headphones
How to fix a gt5 peavey rockmaster amplifier
Hi. My name is Danielle and I have a peavey rockmaster GT-5 guitar mini amp, and it can work with/without the cable. I lost the cable and I didn't need to worry because the amp still worked as long as it had good batteries. But, after about 4 months of no use of it, I put in a brand new battery and the light wouldn't turn on. I looked all over the amp to see if something was missing but I found nothing. I'm really not sure what to do because this is a very good amp and I'd hate to throw it away. Can anyone Help Me?
Mar 24, 2012 | Peavey Electronics Peavey Rockmaster...
Peavey decade manual
Recommend an Ashdown or Fender with a 15" speaker, they will give a good sound, are gig-worthy, and will last. I use a Behringher 120W for rehearsal work, it only has a 12" speaker and thus cannot give a good 'presence', also I have been reliably informed, a lot of custom chips are used in thier amps.
Don't forget, a bass 'E' goes down to something like 60Hz, and a good speaker and amp are a must for bass work
Feb 12, 2012 | Peavey Music
I have a Peavey PV 2600 amp, when it is switched on only the fan works but nothing else. It is three or four years old and it was given to me by a friend, roughly how much would it cost to repair and get...
Either have it fixed or offer it up as broken at auction.
Estimating cost is near impossible, however labor could easily be aver $100.
The fan is controlled by a rather complex circuit depending on thermistor temp sensors. The temp sensors appear to also shutdown the amp.
If the fan comes on instantly, there MAY be a failure in this circuitry which is inexpensive parts...
Each side of the amp has 10 major power transistors and if all were blown it would add significant parts cost to the repair.
Aug 18, 2010 | Peavey Pv 2600 Power Amplifier
PEAVEY XXL AMP HEAD PROBLEM!!! NEED HELP NOW!!!
Hi...
Do you have the Impedance switch set for the right cab?
Are you using a guitar cord to connect to speaker cab ?...If so, dont. Use a speaker cable.
Is the damping switch loose?
Jun 23, 2010 | Audio Players & Recorders
Peavey pv-8.5c input problem.. only one input works
HI...
I work on peaveys quite a bit. That one will need service
A guitar amp / stereo tech would do
Check the web near you for someone
rate my help if this helps
Thanks
Apr 22, 2010 | Peavey PV® 2600 2-Channel Amplifier
I have a peavey supreme xl head thats... well... OOOOLD. at one point i got SUPER pissed and kicked it across the room, causing one of the speaker ouput jacks to fall out. I put it back in and, for a...
Open the unit and inspect for damage and repair as necessary. It does no good to just look at it. Likely something has fallen into the speaker and damage could be worsened if you don't repair it before trying to use it,
Feb 11, 2010 | Peavey Music
Peavey 8.5c amplifier. One channel dead. In
FIrst of all, in bridge mode there is only one channel. The "bridge" means that you combine the two channels together to get a single more powerful amp. The swollen part is probably nothing. Sometimes the plastic caps cup like that. Unless there is a specific problem with the amp, don't worry about it. Try placing the amp into stereo mode and testing each channel. If both work, there is no problem with the amp. If for some reason you need repalcement capactors, contact Peavey directly. They supply replacement parts.
Dan
Mar 19, 2009 | Peavey Audio Players & Recorders
Chicken head knobs
Yep!
I get alot of amp building supplies at Hoffman Amplifiers.
Follow this link and click on the TUBE AMP PARTS button:
http://www.hoffmanamps.com/
Hope this helps!
-mike
Dec 30, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Crate BV120 too quiet
Have the tubes checked when good and warm.
Check for any leacking capacitors.
Check all solder joints are shiny any that are dull try to reheat and apply solder.
Good Luck
BIGRED
Oct 23, 2007 | HHB Radius 50 Tube Amplifier
546 people viewed this question
 Grubhead
Grubhead
