Installing Hard Drive on Dell 8300
Purchased a Western Digital WD2500SB and trying to install into a Dell 8300 and it will not boot up
I don't know what to do or how to do it ... can someone give me step by step instructions or a place on the Web where I can find easy instructions.
  • jebalch Feb 01, 2008
    This hard drive will be the main drive for the Dell 8300 as Dell told us per phone conversation that the other one was gone. I don't know if it came with a CD installer or not...should it have?
    Brigadier General:
  • 6,966 Answers
I am assuming that you are installing the Western Digital WD2500SB as a second Hard Disk in your Dell 8300. If it is connected along the same flat IDE cable as you old/original HD (Primary Master), you need to move the jumper in the WD for it to be as the Primary Slave. Instructions and illustrations are normally printed on the sticker atop the HD. If you are connecting it to the 2nd (Secondary) IDE, pls verify that it is not in conflict to any other device attached to it such as your CD/DVD. At any time, only 1 can be a master and the second device be the slave.
To verify that indeed your wiring/jumper and settings are correct, you can go to BIOS/CMOS setup immediately after powerup and determine if your PC has auto detected the new HD as well as the old/original HD & CD/DVD.
If for wahtever reason, the PC will not auto detect the new (Western Digital WD2500SB) HD and since it is new then, it should still be covered by the warranty and you can ask for a replacement.
If on the other handyou would want it to the the primary master and you would like to run your PC's OS on that new HD, you would need a CD installer/recovery to re-install the operating system.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 01, 2008
  • Louie  Role
    Louie Role Feb 01, 2008
    Apologies to krihard, it would seem you have posted while I was composing my reply. Didn't mean to double up.
  • Louie  Role
    Hi jebalch ,
    With the indulgence of krihard...
    Understand now that the new Western Digital WD2500SB is meant to replace the defective original HD of your Dell 8300. The WD does not normally come with an installer CD, but your Dell 8300 should have one when it was new. Those Dell Recovery CDs are necessary for you to be able to re-install your Windows as well as the appropriate drivers inherent to your PC.
    If for some reason the Dell recovery CDs are no longer available, your options are:
    1. Call again their support and inquire how to get a new copy of the CD;
    2. Borrow an OEM Windows installer. This version should match the particular version of Windows you were originally using in the now defective HD. It can also be determine by looking at the MS sticker either at the side casing or at the rear of your PC. It should say something like Windows XP home or Pro, Media Center or something like that. when asked for the CD key, use the numbers printed on the same sticker. for the drivers, you need to download them from the Dell website.
    Cheers all.
  • 407 Answers
Hi if you hard drive new you patation with xp booteble cd...
conect your hard drive ide port 40pins then ide port bule part conect motherboard ....other part conect hard drive then jumper setting conect right 6 pins ..2pins conect 1st point it call master if is motherboard guied look &conect jumper setting ...then go to reset cpu press del key go to bois select boot divice  enter... then select 1st boot divice is cd or dvd rom divice....press f10 to save yes enter reset pc then setup cd load .......
Helloo i have problem with WD 1600AAJS not boot i can see bios hellp my please i dont now wath wii do.
trying re-installing windows again. before that get into the bios of the pc and check the connected devices to see if the hard drive is being detected.let me know if u need more info.
Apr 03, 2011 | Western Digital Caviar SE WD1600AAJS 160...
Western Digital 1 TB External Hard Drive and BSOD
perhaps the new hard drive is bad western digital software is junk take it back and get seagate external w/freeagent on it
Dec 31, 2009 | Western Digital My Book Essential Edition...
2nd hard drive on Dell Dimension 8300 ( both ATA)
setup the original harddrive as master and the new one as slave then the drive that comes up as c will be the master and the others will follow suit and when you install the games just change it in the install
Jul 20, 2009 | Western Digital Caviar SE16 WD5000AAKB -...
Western digital wd 500gb external hard drive not showing the icon
Doewnload Testdisk and run it to see if it can find a boot sector.
Oct 04, 2017 | Western Digital 500GB My Book World...
Replaced hard drive but unable to re-install version of windows
hi,
have you checked is the drive detected in the system bios, because if it is detected in system bios only then can vista install on it, start the system and at the blue dell logo tap F2 to enter setup and check if you see the newly installed hard drive on the system bios.
Further Queries are welcome
Feb 26, 2009 | Computers & Internet
I don't know how old is your laptop I know a lot of people they try to install larger hard drive but you have to check if your laptop or PC will see that hard drive some it will automatic will will do partition like for the original hard drive capacity and the rest will be hidden. Research your laptop capabilities up to how many gigs can operate. click start, click control panel, click administrator tools, on the left side you will see disk management, click disk management, and you will see the C: drive and will show how many gig and the rest will be not format and partition. I hope this will solve your problem. You can format the rest of the hard drive and rename and asign D: or H.
HH
Jan 31, 2009 | Western Digital Scorpio WD1600BEVS 160 GB...
Upgraded hard drive, from 80gb to 250gb. I have had to reload my os twice. it appears that the bios is not recognizing my hd. a friend said that the inspiron 6000 does not do well with a hd bigger then...
I dont think we can use a hard disk of 160gb in an inspiron 6000. and make sure you bought a ATA hard drive and not a SATA drive. For the Western digital try to reinstall XP and install the device drivers before installing application s/w.
Dec 19, 2008 | Dell Inspiron 6000 Notebook
SCSI vs. SATA vs. PCI Controllers
to use your external hard drive as boot drive you will need to set bios to boot from it if the bios allows you to
i do not know which section of the dell bios it is but it will have boot order or similar you will have to follow instruction to set it the main problem having extenal boot is windows will not install to USB devices
As for the hard drive from dell it could be a sata drive they sold you you need the standard one
Hope this helps your dilemma
Jul 31, 2008 | Adapters.com Video to Monitor HD-15...
Western Digital Hard Drive will not power on
try to change the power adapter..
its mayb broken..
happy trying..
good luck..
Apr 14, 2008 | Western Digital My Book Essential Edition...
Install hard drive
you need to be a bit more specif please, try and provide as much info as possible
Dec 16, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Computers & Internet Logo
944 people viewed this question
David Payne
David Payne
