Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
TV turned off by itself and now blinks red led 6 times
I have a Sony grand wega KDF 55W655 and thought the bulb burnt out because of the red blinking light, so i changed it and the tv still doesn't work. That didn't change the 6 flashes of the red led on the power/standby light at all. Can you please give me any advice on what to do next. I would sure appreciate it.
  • 6 more comments
  • bigmig Feb 02, 2008
    Tv went darker last night and this morning all I got was a constant blinking red light under lamp.  Do I simply need to change the lamp?  I have a 55 inch - same model
  • Anonymous Feb 06, 2008
    I have the same problem with KDF55WF655. The standby/power light blinks 6 times over and over but the picture dose not light on. I took the lamp out and it looks good. any ideas...
  • megakwan Feb 07, 2008
    when i turn my sony wega 48" tv on i hear sound until the standy by red light blinks 10 time then stops when it starts back blinking the tv turns off.
    is there anyone who knows how to fix this problem halla back 340 513 8062
  • Hate Sony Feb 11, 2008
    I have the same exact problem, happened 2 days ago. I find it funny that at least 5 of the exact same tv's went out in about 1 week. Has anyone out there found out yet how to fix this "low B error", and how much did it cost?
  • Anonymous Feb 20, 2008
    TV will come on with green lights and about 4 sylables can be heard of a program - then no sound and the red light starts blinking in 4's. This has been going on for about 6 months. At first we were running the dust buster over the fan vent covers in the back - not sure why - but it worked and the TV would come on. Now we are up to using canned air, which also works but the red blink attacks are getting more frequent.
  • melissa0719 Nov 10, 2008
    We have the same problem. We replaced the bulb 2 months ago and now the tv continues to shut off and go on standby for about 10 -15 seconds before powering back up and this happens about every 7-10 minutes.
    AAAHHH!!!
    Any suggestions?
  • Anonymous Nov 12, 2008
    My tv goes black, looses sound too. I was getting 5 red flashes. I took out the buld and vacuumed the grilles. This worked for a week or two. Now tv keeps loosing picture and sound every few minutes and it comes back..... Any ideas???
  • Anonymous Nov 25, 2008
    I have the same problem my tv turns off about every minute for about 15 seconds then turns back on. Any suggestions
  • Sony Master
  • 8,617 Answers
6 blinks means a low B error. Which is no DD 6volt output on G1 board . This will cause no picture and no sound. To fix this yourself you would need the manual to get the correct sequence to test and proper part to order. You can get a service manual for 10.99 at the following link and they will ask if you'd like it emailed to you after purchase. Here is the link,
http://servicemanuals.vstore.ca/
Posted on Feb 01, 2008
After replacing the bulb and the tv still didn't work, I then replaced the thermal fuse and that fixed it. The thermal fuse costed about $12.00 and is basically a wire that wraps around the bulb housing to prevent the bulb from overheating. Fortunately the local sony repair shop had one in stock. I figure the dust had built up inside the tv and prevented the cooling fan from circulating the air properly around the bulb housing. Hopes this helps..
Posted on Feb 19, 2008
2007 RCA 32 inch TV that is about 3 months old has gone out and now it flashes the power light 25 times but won't power up.
Posted on Feb 18, 2008
My sony led tv model # kdl60ex700 blinks 6 times my sonny TV blink 6 times model # KDL-60EX700. What is wrong
I need more information like:
When it is turned on,
Turning off,
Connecting to something,
To close to the wall......Things like this to better you with your problem.
Aug 27, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
KDF-60XBR950 red light blinking 6 times. Please help.
red light usally means bulb is no good, not in properly, or is overheating. if you turn it on and it goes off in short time and starts blinking red then its the bulb for sure. they get hot then kick out and blink..
Aug 18, 2013 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv will not turn on red standby light blinks 6 times
tv will not turn on red standby light blinks 6, on a sony grand wega kdf-55xs955 55 in. rear projection hdtv television
Jun 19, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
6 blinking red lights
You still have your guessed problem. 6 blinks means Low B+ error (power supply). This can be caused by an open thermal fuse, loading by another circuit board, or the power supply itself.
Apr 13, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Grand wega kdf-55wf655, won't power on and led flashes 3 times
Make sure lamp cover is placed properly and securely after lamp replacement.
3 blinks of LED shows lamp door is still open or not closed properly.
Jul 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Jul 10, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
733 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
