Question about Insignia NS-DV2G MP3 Player
Dont know how it works?
I would like to no how to use my mp3 player? I have tried to connect it to my computer but it does not work..
How do i get video
Posted on Feb 05, 2008
My computer cannot recognize it at all and i dont know where to the msc on or off in the settings too
Hi
Try and reset the player by inserting a pointed object inside the small hole, press and hold for 5-10 seconds to let the player reset. If this doesn't work then connect the player with the computer and let it charge for a while. Now go to control panel-> administrative tools-> computer management/system management-> storage, check if you are able to see the mp3 player here. If it is visible then try a reset and try again. If not then reset the player while it is connected with the system. This will resolve your issue.
Hope this helps...
Daniel
Aug 28, 2010 | SanDisk Sansa e260 MP3 Player
I dont know the steps to putting music on my pearl rca?
ok first off there are a few ways to do this the most easy way i know is just using My Computer in windows and finding the icon that is your mp3 player or is listed as a usb storage device, open that up and look for a folder called music and if none exist then try just draging and dropping your music into that folder and see if that works. Next if that wont work try opening up windows media player, then connect your mp3 player, then goto the sync button at the top of the screen and see if your mp3 player is listed if it is then go back to the media library button and start draging your music that you want on there to the sync list on the side and after your done click sync. hope this helps
Sep 22, 2009 | RCA TH1101 MP3 Player
Dont know how to delete songs from player
You may have automatic synchronization set up with Windows Media Player - if this is true, disable it. If you don't use manual sync, then you will have no control over what goes on or off your mp3 player.
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Mar 18, 2009 | SanDisk Sansa e200 MP3 Player
A fool
what kind of mp3 do you have software for it do you have a cord to connect to computer if you have acord connect it to computer with mp3 connected and windows media should pick up the connection
or real player will work
Jan 04, 2009 | Sony Audio Players & Recorders
Non connecting
Slide the hold button to lock and then connect it. It worked on mine.
Sep 30, 2008 | SanDisk Sansa e200 MP3 Player
Cant get mp3 player working
How are you trying to get them to work? Are you trying to turn them on, play music, connect to the computer or what?
Aug 09, 2008 | Coby MP-C7085 MP3 Player
Same...
What you can try is to remove the software off your computer not the firmware the software that came with the mp3 player if you remove this then when you plug your mp3 player in it should give you message new device found then you could try installing the software again then it might be able to let you use the firmware update.
As you have tried the lead and also your usb port then you know that they are working fine.
Just try removing the software that came with the mp3 player then give it another try this way when you plug the mp3 player in the computer wont know what it is and tell you new device found.
If it dont say this then you know the mp3 player is to fault and not any of the software on your computer give this a try then get back to me ok.
Once software is removed when you plug it back in it will say new device found and it will come up under my computer as mass storage device if this happens then put the mp3 player into recovery mode then try running the firmware.
Let me know what happens ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Still messed up.
hi yes it should be in recovery mode when doing this
does the firmware tell you when to connect the mp3 player to computer once in recovery mode open firmware file then when it asks to connect then plug into your comp if it dont work this way then plug into comp before opening firmware file give this way a try also.
But the mp3 player needs to be in recovery mode whilst doing this
if this still dont work then try a different usb port failing this then their is a problem with either the cable or usb port or conection on mp3 check cable and connections at both ends make sure no dirt or paper is stuck in mp3 end ok
My nextbase mp3 is not working..
in this case i would like you to connect your mp3 to the computer,after that when it actually connects go to it's icon and right click and go to format then completely format the mp3 player and try to restart you player
rate me
Apr 07, 2008 | Audio Players & Recorders
Insignia NS-DV2G MP3 Player Logo
27 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
