Question about Dell Dimension 5100 (D51L1) PC Desktop
Computer not starting up
Hi all
I have a dell dimension 5100 pc..when i put it on it appears to start until the screen with the dell logo and the status bar which says Bios revision loading appears. The status bar advances till almost 100% but then stops. Nothing responds the F2 and F12 key doesn't bring any response..the light by the floppy drive remains on and the lights 1 and 4 remain on right below the floppy drive..i do not kno wat is the problem and assistance wud b appreciated
  • LouisBrady Feb 06, 2008
    I have the same problem. I have reseated the RAM and the video card. I also removed my ATI graphics card and then used the on-board card. But the problem remains!
  • Anonymous Mar 29, 2014
    The status bar doesn't even start to fill up. Just stays stuck at the BIOS screen and won't respond to F2 or F12 or anything else.
Try Cleaning Ram Fingers with rubber and re inserting could be a bit of corrosion or moisture/fluff this often works
Posted on Feb 01, 2008
Restore factory settings
You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Jan 30, 2014 | Dell Dimension C521 PC Desktop
Dell dimension 5100 has no video
If the computer is actually starting, then I would connect another monitor to it to see if there is a video signal. If you have no luck, then you have a video card problem.
Of course, there could be another problem keeping the computer from starting. For instance, do you see any messages on the screen at all? If you do, then it's probably not the monitor. It is probably a hardware issue--so you need to troubleshoot your system.
Oct 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
How can i go to bios setup
Straight from the Dell website:
  1. Turn on (or restart) your computer.
  2. When "F2 = Setup, F12 = Boot Menu" appears in the upper-right corner of the screen, press .
If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop. Then shut down your computer and try again.
I hope this answers your question!
Apr 15, 2011 | Dell Dimension 2400 PC Desktop
On powerup of Dell Dimension 5100 running Windows XP the computer hangs with diagnostic lights 1, 2 and 3 a steady green and 4 off. The onscreen message is: 300XT BIOS P.N 113-A33437-102 which appears on a...
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Nov 05, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Dimension 5100 and windows xp pro SP3 clean install
Well if you have it installed on the computer and cant get past the Windows logo. Put the SP3 disk in and do a repair. Make sure you hit -R and not the repair button after clicking continue. Well the directions for a repair will be on the screen. That is my thoughts on what you should do. If you have already done this, then I'm not sure where you should head to next. Hope this helps!!
Mar 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Can not get into safty mode get floppy diskette seek failure i have a dell dimension 5150
restart the pc and press F2 immediately after the dell logo comes on.
go into BIOS and disable the floppy drive. exit and restart the pc.
Feb 23, 2009 | Dell Dimension 2400 PC Desktop
Changing the BIOS
to boot the computer from the cd
Turn off the computer and then turn the computer on
again.
3 When the blue Dell logo appears, press <F12> immediately.
the computer and try again.
4 Use the arrow keys to select the CD-ROM option, and then press
<Enter>.
Feb 14, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Blue error screen when starting up computer
looks like a OS software problem on reboot try pressing F8 and choose last good known configuration
if that fails to do the trick
This option will put your comp back to how it was when you bought is so all you saved stuff will be lost
press contrl and F12 together on boot up this will restart pc as it was when bought new
Aug 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
96 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
