Question about Dryers
Sudden "plant" smell in dryer
I have an old Amana electric dryer (about twelve years old, I think.) Just now when I took a few items out of the dryer I noticed a very strange smell. I can't identify it, but it's sort of like plants or weeds. I went outside to see if the vines outside the house were interfering with the dryer vent. They weren't growing right over it, but they were around it and dryer lint was sticking out of the vent. I cleared away the lint; it was just at the mouth of the vent.
Could plant dust have gotten sucked inside? Do you think dryer lint is trapped in the hose? The clothes dried without a problem and they do not smell. The smell is in the laundry room as well as inside the dryer.
  • barnbunny Feb 01, 2008
    I think that when the lawn people were here last, they blew plant materials into the vent.
    This morning I noticed what seemed to be a lot of lint BELOW the regular lint trap. I used a round, flexible bristle brush made for drains to clear as much of it out as I could, and then I used my narrow vaccum nozzle to vaccum as much as I could. Then I turned on the dryer to "no heat." I heard some funky noises, like particles flying around. I ran outside in time to clear a little more lint that was stuck against the "anti-mouse" flaps of the dryer vent. The air seems to be blowing out of the dryer vent just fine.
    I've been running the dryer on "no heat" for the past few hours, but the smell is not going away. I don't hear any unusual noises. Do you think it will take lots of running to push whatever materials are in the hose out? Should I run the dryer with heat, perhaps to dry out anything damp?
    Another person suggested to check "inside the cabinet" for lint buildup, but how do I do that?
    Genius:
  • 3,422 Answers
check for blown fuses or tripped breakers. If so, then check your wiring. :)
The motor may be getting too hot, I would check the inside of the cabinet for lint buildup, and insure that the motor can breathe. Other than that, the bearing might going out ...especially if it keeps making noise on the 2nd load.
Goodluck,
Don't forget to rate me as fixya..
Posted on Feb 01, 2008
  • Priya darshan Feb 01, 2008
    Go to the below two links it will explain you step by step as how to check cabinet for lint..
    http://www.ehow.com/how_2074306_fix-drye...
    http://aaa-applianceparts.com/dryer.htm
    Please don't forget to rate me as fixya..
    For safety, some manufacturers recommend unplugging the dryer and
    turning off the gas supply (if you have a gas dryer) before
    disconnecting the vent tube.
  • 871 Answers
Hi barn bunny,
you probably have something inside the lid and since it is emitting a strange smell, it is most likely. what you can do is have it clean just to be sure and try to sample clean it with water. to get rid of the smell, you can use citrus to give you that natural smell.
hope this helps you.
goo luck... fixya!
  • earl norman llanera
    earl norman llanera Feb 02, 2008
    checking the insides of your vent aint an easy task, you should have someone with you to assist and like what you mention, you ran outside... have someone at the outside check the vent while you are in the inside. my only suggestion since the lint is not the case anymore, have someone or something you can use see the insdes like using a mirror or something because i could imagine that there might be something inside there thats trapped and moist thats why the smell wont go away.
  • 1,512 Answers
Just check that the vine has not grown back into the vent If it has then that may certainly create the effect you have noticed. The vent has only exhaust from the dryer going to the outside. The heated air and water vapor from the dryer may have instilled a smell from the vine you mentioned. but would need an open window or the like nearby to vent the smell back into the room. Under certain wind directions and strenght you may also experience some flow back of smells from outside back into the room after the dryer was turned off, this would not happen when the dryer was on(blowing in an outwards direction). Hope that this has helped you. Happy to talk to you more about it if the smell lingers.
  • Graeme Ross
    Graeme Ross Feb 09, 2008
    And it the smells continue, it may well be worth having the machine diassembld to check for vermin. A nice little mouse family may be living in the vent or the unit...
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
I have a two year old dryer that all of a sudden there is a loud rattling sound in it and slight burning smell. I'm not sure if that smell was there before but it's almost as if there is somthing inside...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 15, 2011 | Amana ALG331RAW Gas Dryer
The dryer is 8 years old. When I push in the dial
the motor is not turning and that's what is humming,you either have a bad motor,something stuck in the blower usually a sock or the belt is stuck
Nov 02, 2009 | Amana DLE330RAW Electric Dryer
Kenmore dryer runs great but no heat
am sending you the information I have so you can ask me with the names of the parts you want me to assist you.
If nither of this match to your dryer I need the model n serial# .
your retiing is very important for me
was this helpful?
May 20, 2009 | Dryers
Smells like it's burning and smoke coming out of chimney vent
Get the filter housing out of the machine and wash it out. Blow out the blowers housing. Change the control thermostat.It mounts right next to the fuse on the back:
Dec 07, 2008 | Roper REX4634KQ Electric Dryer
I have an Amana Elec. Dryer. Model # DLE 330 RAW that all of sudden quit heating. This dryer is about five years old. It has 7 cycles and 3 temp controls. Could this be a bad heat control switch or a...
It could be a circuit breaker, fuse, or electrical problem. Just because the motor runs doesnt mean it will heat.
You should check for power first.
Then unplug the dryer remove the lower front panel, two screws.
Mark and label any wire you remove so you know where they go!
in the back on the left is the heating element, check for burnt wires, take the element out and check for a broken wire on the back side also check all the thermostats, and electrical components to make sure they are good.
ask more questions if needed
Jul 15, 2008 | Amana Dryers
Dryers Logo
103 people viewed this question
Top Dryers Experts
