Question about Akai PDP42Z5TA 42 in. Plasma Television
What is an hv cable?
Trying to figure out why spots emerge. manual says check to see there is no emitter sources (car HV cable or Neon lamp) or other possible interference sources.
what does this mean?
    Brigadier General:
  • 6,966 Answers
If I may add to the postings of devocap and coolguy008 (and with their indulgence)...
Often, HV would refer to high voltage cables. These are ordinary wires but with extremely thick insulation. Some later day versions uses highly conductive carbon inserts instead of wire to reduce electrical noise emissions. They are used where the voltages transmitted are considerably higher than normally used. Examples are:
1. Sparkplug wires
2. Power leads to neon light advertisements
3. wire from the flyback transformer to anode cap in picture tubes.
Possible sources of electrical noise (that uses HV cables)
a. 2 stroke engines such as those in some lawn mowers, chainsaws, old models of snowmobiles, outboard engines, dirt bikes;
b. neon signs such as those in cafes, clubs, hotels, public places.
Hope that this be of additional help/idea other than those posted by devocap and coolguy008.
Good luck and kind regards.
Posted on Feb 02, 2008
    Sergeant:
  • 201 Answers
Hey there ShelleySmith, they are basically referring to anything that is conducting an electrical current, around or near your TV. in particular, neon lights, microwave ovens, etc.Also watch for things that can generate static charge. If you can't identify any potential interference, you could move your tv to another area or room to see if this is still an issue there Good Luck!
Posted on Feb 01, 2008
    Genius:
  • 3,422 Answers
It's a 5 wire cable that transmits HD signals from your HD components to your HD TV... unlike the 3 wire ones you use to connect VCRs and DVD to TVs... they permit a faster signal speed and allow for a higher bandwidth ! HV may mean HI VOLTAGE witch can cause electro magnetic interference with your tv. When an ac current passes through a cord a magnetic field opens and closes along the cord and sometimes unwanted RF can leak in to your devices via this magnetic field.They are not too expensive..
Goodluck,
Don't forget to arte me as fixya..
Kenmore elite microwave model no. 721.66339011 just stopped heating ...anyone know what or how to fix?
Hello, the fuse normally is located behind the control panel and easily accessed by removing the panel. Here is a schematic to assist you in locating the part...
Dec 17, 2016 | Kenmore Microwave Ovens
Won't start weak spark
Hi Karl
Faulty Magneto coil or points or condenser (capacitor) or HV Wire if it uses carbon instead of wire. (This is for radio suppression)
Carbon resistor inside spark plug? Use another Spark Plug.
Rule of thumb is 25 tho contact Gap - thickness of standard hacksaw blade.
Use cheap Neon light tester close to HV Silicon Insulation & compare brightness to e.g. car HV cable.
Happy Mowing
Sep 13, 2015 | Garden
My 05 neon automatic has the check engine light on and shift after 2nd gear
poss vss (veh speed sensor) malfunction.cost arnd 7 to 30 $ depending on which one you hv, however i wld take to autozone or advance auto, they generally will hook up the obd connnector and get the trouble code, and they don't charge to do so, (to my understanding that's all their stores.) so if they try to charge you, go further
Aug 28, 2012 | 2005 Dodge Neon
Hi, I'm looking for user manual of Omron elepuls HV-F126
Hello -
I do not find a manual for the HV-F176 Omron Elepuls low-frequency massager on either the Omron Healthcare United States web site,
https://omronhealthcare.com/
or on the Omron Healthcare international website,
https://www.omron-healthcare.com/en/products/painmanagement
Therefore, if you reside in the USA, I suggest you contact Omron Healthcare customer service and ask about the availability of the user manual for model HV-F176. There may be a copy of the manual of the discontinued massager in the company Archives. If so, there may be a charge for a copy,
See the Contact Us (USA) information here:
https://omronhealthcare.com/contact-us/
There you will find a toll free (USA) phone number as well as a form to complete to send an email message.
Best wishes.
Feb 22, 2012 | Health & Beauty
I have a Phillips 42PFL3704D/F7 that has no picture. Sound works and I can turn the volume up and down. I placed a flashlight close to it at different angles and i think i see an image (not sure). If I...
If you can put a light source behind the screen and see an image, then your lamp has gone out. LCD's have an image on the screen but need the light source to show the picture because they do no emitt light themselves.
Jun 08, 2011 | Televison & Video
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
The light is out.
Usually, you have to remove the outer case after pulling the power cord and wait for maybe 10 minutes to make sure the HV power supply has discharged itself. The lamp should be plainly visible at this point. Be sure to use the same wattage lamp as the original. Good luck!
Jul 02, 2010 | GE JVM1540SMSS Microwave Oven
The driver on modem Sis sw modem for Notebook Sahara NB 610 LE1D is necessary
i hv a nokia 7610 n i want 2 connect it through data cable.m usin idea internet n hv installed pc suite also.i hv tried other nokia fones lyk 6630 n72 its working in it ......n same time i hv tried other 7610 but its not working in it.......plz help
Mar 15, 2009 | Computers & Internet
How do I remove the HV lines on the D board?
Do not cut them.
Push and twist thicker wire in HV block and pull out. HV block has 3 more wires going to 3 guns in TV.
Never cut this wire.
Feb 25, 2009 | Sony KP-61HS10 61" Rear Projection...
Spots
If I may add to the postings of devocap and coolguy008 (and with their indulgence) in your other posting.
1. Sparkplug wires
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Akai PDP42Z5TA 42 in. Plasma Television Logo
77 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
