Re: Occasionally displays "safety lock on". How do I...
I think I actually know what happened to you. The safety lock prevents you from viewing certain menu items while in motion. In order for you to see those items again, you must first stop moving completely, then reopen the menu. From there, you can disable the safety lock.
Usually it's the other way round.some cars have a safety feature that locks the doors automatically upon start to protect children and passengers from accidentally opening a door during transit.i believe you can override this feature but you would need to know what make model and key fob type to research via internet.
You can't override the door lock It's a safety feature. You can bypass it by connecting the wires that go to the switch but please don't! It means the door can be opened while the drum is still spinring and children can be severely injured. You may also open the door accidentally with water in the tub. If you think there is a fault with the door lock, first make sure it's not just a blocked air tube, but replace it rather than try to override it.
Usually there are switches inside the door jam of the rear doors. Move lever over to use the child safety locks. Occasionally the drivers side window/locks master controls will have a switch for this also. Mike
Your black ended driver key should open the glove box. The valet key is not made to open it, thats the safty feature in it. There is no overide for the Valet settings, you have to unlock the glove box with Driver (master or black) key and turn the Valet switch off. Also the Valet switch does not engage the glove box lock so over riding the Valet security wouldnt open it even if you could over ride. If the Valet key would unlock it or was easy to overide then it wouldnt be a very good safety feature. Best of luck, hope you can get it opened.
since you have an unit that offers a child safety lock system find the location where the lock image is and push and hold that button for at least 5sec on until it beep or lock msg is gone some models you have to hold up to 15secs this is to allow the patience of children to move on quickly
Sounds like you need a new shifter assembly, or the brake switch. Most likely will be the shifter though if you can move it out of park with the override.
Use these instuctions if your Deville has an Analog Instrument Cluster 1.Press OFF and WARM buttons onClimate Control Panel (CCP) simultaneously. (Instrument Panel Cluster (IPC) will light all telltales, then go blank) System is now in diagnostic mode. Press PASSENGER COOLER button until “RFA” is displayed, then press FAN UP. If“RFA DATA” is displayed, press FAN DOWN. If“RFA OVERRIDE” is displayed, press FAN UP. 2.If“RFA 500 NO OVERRIDE” is displayed, press FAN DOWN. If“RFA 501 PROGRAM FOB #1” is displayed, Press FAN UP. 3.IPC will show “0” on right side of Driver Information Center (DIC) display. Press warmer button on climate control unit until “99” is displayed. 4.Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not programmed within 30 seconds after entering “99” override display, system will default and you must begin again at step 2. 5.To program a second remote, press FAN DOWN button until“RFA 502 PROGRAM FOB #2” is displayed, then press FAN UP.Repeat step 4. To exit system, press AUTO, MODE UP, MODE DOWN, or RESET.
Use these instructions if your DeVille has a Digital Instrument Cluster
1.Press OFF and WARM buttons on Climate Control Center (CCC) simultaneously. Instrument Panel Cluster (IPC) will light all telltales, go blank then enter DIAGNOSTICMODE. Press FAN DOW button to scroll through system until “RFA” is displayed, then press FAN UP button. Press FAN DOWN button until “RFA OVERRIDE” is displayed, then press FAN UP button. When“NO OVRD RF 500” is displayed, then press FAN UP button. 2.When “PGM FOBL 501” is displayed, press WARM button and “99” will be displayed in left upper corner of IPC just below odometer. System is now ready to program remote. 3.Press and hold TRUNK button on transmitter. While holding TRUNK button, press LOCK button and hold for one second. Hold both buttons for a total of 3 seconds. Locks cycle when programming is complete (if remote is not programmed within 30 seconds after entering “99” override display, system will default and you must begin again at step 2.) 4.To program second remote, pres FAN UP button until “PGM FOB2 502” is displayed, then follow steps 2 and 3 to program second remote. To exit system, press RECIRC or RESET buttons.
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
