Question about Samsung TSL3293HF 32" TV
Samsung TSL3293HF HDTV - TV in Stale State-No picture or audio
TV appears to be in stale state. TV does not display a picture or have audio. Display is black. LED for On/Off switch is green when TV is plug in; however can not turn TV off with switch. Have to unplug cord to power off and plug in cord to turn TV on. After cord is plug in, hear a metalic click and On/Off switch LED lights up green; however no picture or sound. Prior to current condition, TV was working fine without any problems or signs of problem.
  • 2 more comments
  • cdwills Feb 16, 2008
    The TV worked this morning, but stopped this afternoon. All I get is black screen the power button is green. The remote does do anything. When I unplug it a replug it in, I get a relay type click but nothing resets.
  • Anonymous Jul 14, 2008
    I have the same problem. the green light comes on to show that power is getting to the set; however, it won't turn on, no picture or sound.
  • aggig Jul 14, 2008
    I have the same problem. The green light is lit on the power switch to indicate that power is getting to the set; however, when I try to turn on the set, using the power buttoon or the remote, there is no picture or sound. The green power button does not blink like it normally does when the set is powering up. I have tried unplugging it and waiting a few minutes to let it reset. But that did not work.
  • cmphoto1 May 02, 2009
    No power after plug in I get the green light on front but can not get secondary power up...coax loose on back and I have removed it ..Internal 250v fuse has continuity,
Did you get it fixed..I am having the EXACT same problem with mine..would love to knoe how much you are spending. Should I junk it? I have had it for 5 years. Kim
Posted on Apr 21, 2008
  • krendina Apr 21, 2008
    Jason or eshine..help a girl out..How much did it cost? Was it the power module? Kim
  • krendina Apr 25, 2008
    Thanks for nothing
I HAD A REPAIR GUY OUT TODAY AND HE SAID IT WAS THE POWER MODULE. I HAVE NOT GOT A PRICE FOR THE PART OR REPAIR YET.
JASONCBFAN
Posted on Apr 15, 2008
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV display is black; audio works fine. If I turn TV off and then back on the picture does display for a few seconds but then...
The backlight inverter which is also part of the power supply needs to be replaced. If you feel comfortable you can replace the blown capacitors on it.
Feb 10, 2018 | Televison & Video
Spartan display cases blows air on the food to cool it. The problem is that the air has an order of staleness and makes all the food taste stale even if you just made the pastry item. Spartan does not
Try a good cleaning and then put in a open box of baking Soda
Where does the unit get the air from?? just from inside the cabinet or from outside,if outside try to clean air intake and hoses??
Hope to have been of help,good luck Dieter
Jan 04, 2012 | Spartan Showcase 91040-77 Non Refrigerated...
Television display
This normally causes by failure of power supply board. Some time it causes by failure of inverter board, in this case you can see the picture moving on the dark screen as it has no back light.
Aug 18, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Display says 60hz always
Ignore it. That rate (60hz) is what the cable provider is refreshing at as the signal is sent to the box, but the TV will then refresh at 120hz. I know that the manual does not state this, but the TV is working correctly. Go to the "menu" and "picture" and set it accordingly.
Aug 02, 2009 | Samsung LN55B650 55 in. LCD HDTV
Monitor
This is probably a dead pixel area and there may not be anything that can be done other than replacing the screen. This could also be a stale area in the liquid crystal. Try massaging the area firmly, just hard enough to make the screen change color, but not too hard as to make it turn black. If it's a stale area this should refresh it. If it's a dead area, then I'm afraid replacement is the only option.
Jul 19, 2008 | Computers & Internet
In stale samsung d900
if u will right click on the icon then u will find the option un instal click on it then ur problum will solve
Feb 18, 2008 | Lands Phones
Samsung TSL3293HF 32" TV Logo
380 people viewed this question
Henry  Thomas
Henry Thomas
