Question about Bazooka EL1204 Car Subwoofer
Stops working for some reason, it just started today. I was leaving a store, turned on my truck, and started playing the subs, within about 3 seconds, they stopped working. the subs randomely stop, and randomely turn back on, but however, when they turn back on, once the volume gets to a certain point( and nothing that is too loud, i mean the volume is actually fairly low) the subs will quit, and randomely turn back on at a later time, once again though, when i raise the volume on my head unit, the subs disapeer. I checked the wires, power is fine, remote is fine, and ground looks good, does anyone know wat this problem could be from ?
  • williams04x Feb 08, 2008
    ya, thats wat i thought, so under the hood i went, it turned out, the connection to the battery terminal was jsut a lil loose, so when the volume got loud, and it moved around, allowing the power to the amp to be interfierd with, now im faced with bigger problems, getting a new clutch for my truck ahah
    New Friend:
  • 101 Answers
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
Posted on Feb 01, 2008
  • chris ZAMBROTTA
    chris ZAMBROTTA Feb 08, 2008
    IF ITS NIOT 1 THING IT'S ANOTHER GOOD LUCK.CAN I GET A FIXYA RATING FOR TRYING? BY THE WAY I'M ALSO A MECHANIC. WHAT MODEL TRUCK?
  • chris ZAMBROTTA
    chris ZAMBROTTA Jun 16, 2008
    you forgot 2 rate.
Thumping machine gun sound
If you've never worked in electronics this is not the way to start unfortunately. You say it was spilled on the power plug end of the cord. That should haven't created the issue. Plug it into an unharmed outlet and see if the issue remains. Make sure the plug isn't still contaminated before you try. If the issue persists you will have to decide if the cost of repair is more reasonable than replacing it outright. Your issue sounds similar to a term known as "motor boating". I would guess the power supply is cycling off and on quickly causing the sound you hear. Due to the way these things operate it could be any one of several things. Advice is to not let it continue this for very long or the whole thing will fail making it too costly to repair, turning it into a great table lamp stand!
May 21, 2016 | Audio Players & Recorders
It will run for awhile then it will just stop and want crank back up im thinking fuel pump because today it quit and i sprayed some starting fluid in to the breather and it tried to start then i had it...
This sounds like an electrical issue.
You will need to extract the diagnostic codes from your vehicle's computer.
This can be done in the following manner:
** Firstly, attempt the first part of the procedure with engine running **
- With gear lever in PARK, start engine and rev up to 2,500rpm, then gradually reduce revs down to idle speed (ie take foot off accelerator).
- Cycle gear lever through the gears (ie down to 1st, then back up to PARK)
- Turn Airconditioning to ON, then OFF
- Turn engine OFF
- Within 5 seconds, turn the Ignition Key in this sequence: ON - OFF, ON - OFF, ON (leave key in ON position)
- If done correctly, a series of 4-digit codes will appear in your ODOMETER display
** Remember, you must complete the ignition key sequence, within 5 seconds.
Please advise which codes appear and I will assist you futher.
Cheers,
Scott
Jul 13, 2011 | 1999 Jeep Grand Cherokee
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
I have a sony explode cd player. It is an older one and has been sitting in a garage for about 3 years. We hooked it up today and my subs will not play when a cd is playing but the subs will play in...
It sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire ( amplifier remote turn on) to turn your amp on. The power antenna remote turns off when leaving tuner mode.
May 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
I need to program a new fob. am reusing the old key! can you help?
  1. Turn the ignition to ON, then wait 10 minutes for the next step in the programming sequence.
  2. After the 10 minutes has elapsed, the car horn will chirp once. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  3. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp twice. Turn the ignition switch to the OFF position within 5 minutes after the horn has sounded, then to the ON position within 5 seconds after switching it OFF.
  4. Leave the key to the ON position for 10 minutes . After the 10 minutes has elapsed, the car horn will chirp 3 times.
  5. Verify that the security indicator in the instrument cluster has stopped flashing and attempt to start the vehicle.
  6. Turn the ignition to OFF and remove the key from the ignition switch.
  7. Move approximately 3 meters (10 ft) away from the vehicle and test the transmitter functions to validate that the transmitter has been programmed successfully.
Mar 30, 2011 | 2006 Pontiac GTO
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
3) The answering system announces the current time and the number of messages
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
5) After the command has finished, you hear intermittent beeps indicating that the
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
Anti-theft has engaged
sounds like the transmitter in the key head is defective or it lost programming, try these programing steps, if that doesn't do it u need another key made.
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door
locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to confirm
programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle again to
confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Apr 19, 2009 | Mercury Mariner Cars & Trucks
Crackling coming from Velodyne DD-10 subwoofer
One of 2 things is going on.
First, the servo mounted in the driver may be going bad or is picking up some noise.
Second, Something in the amp section is going bad, hard to pinpoint the exact problem.
you say that it plays, so I tend to think it is the driver mounted servo unit.
If it is within the warranty time, take the unit back to the retailer you purchased it from, if not contact Velodyne for repair.
Mar 18, 2009 | Velodyne HGS-10 Subwoofer
Sub won't stay powered up
well if your getting sound out of your surround speakers then the sub is busted, if your getting no sound at all then your speaker input's are either bad or out... i would test the speaker inputs...
Aug 09, 2008 | JVC TH-C30 System
Checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
touch-tone telephone.
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
4) Enter a command within 15 seconds, each command there after must be entered within 2
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Dec 29, 2007 | Uniden DCT648-3 Cordless Phone
Bazooka EL1204 Car Subwoofer Logo
201 people viewed this question
Top Bazooka Car Audio & Video Experts
Mark Skinner
rd2xpld
FastHarley
FastHarley
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
