Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Refrigerator Water (ice) build up in bottom of freezer. Water to icemaker and door turned off.
  • 68bentwrench Feb 12, 2008
    Right on the money! Problem fixed. Thanks,
I just fixed similar issue. Defrost drain plugged. Take back panel off and behind fan is back hose. Take it out from the bottom and use something like coat hanger to unplug.
Also need to take off front panel from inside freezer and remove ice build up and thaw with hot water or hair dryer. Once done you should notice water in drain pan from back. Put all together.
Posted on Feb 07, 2008
Electrolux french door w/freezer in bottom stops making ice.have turned it off overnight but it will not start bsck. what can I do , I have used hair dryer to thaw it and that worked several times but...
You failed to give a model# so I can refer to which bottom freezer you have..
Electrolux can be a tricky product to work on and I do not know if you have the icemaker solely in the freezer, or if you have the icemaker in the refrigerator section with ice and water in the door. Or if you have two icemakers as some of them now have because the one in the fridge breaks so much.
Hair dryers are a bad idea no matter how you look at it.. Many times, I have gone to do a repair and found disfigured plastic parts due to the customer trying to fix it themselves off a youtube video. The plastic they use is good in the cold but becomes very pliable when heated and tends to distort easily.
So... If it is the one in the bottom (freezer section) then it could fall under a service flash regarding interior moisture building up around the evap fan blades. Or it could be a bad water valve depending on what it is that you are thawing out..
If it is for the icemaker in the refrigerator section then there has been numerous fixes for this with the most current being part # 5303918784 which also addresses interior moisture.
I have also found that the defrost heater for the icemaker evaporator goes bad for the icemaker in the refrigerator section and have replaced quite a few lately.
If you need more help, please give more information specifically the model#.
frigidaire-ffhb2740ps2-ice-maker-air-handler-housing-gasket-kit-genuine-oem-5dtrzrhacenyq0nfrt1kdhhl-3-0.jpg
Jan 29, 2018 | Refrigerators
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
The freezer side every 2 to 3 days the fan makes a noise and the ice begins to melt. It drips from the ice dispenser. The following day every thing is frozen again. The refrigerator stays cold.
This may sound a bit harsh but turn off the water to your icemaker for several days. What your describing sounds like the icemaker water valve is leaking water by the diaphram and is leaking into your freezer. This is a common symptom of failing ice maker water valves. I just went through this on my own personal refrigerator where ice was building up. After changing the icemaker water valve all the ice build up ceased.
So turn off the icemaker water supply for a few days.. break out the ice trays if need be and see if the ice build up stops. If it does then the ice maker water valve will need to be replaced. Fyi they run $38 to 55.00 on average and you can change it yourself. Should the need arise here is a link to a replacement water valve source: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=113933&diagram_id=337176#d337176
Close up view: http://www.appliancepartspros.com/part_details.aspx?part_id=4298908
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Frigidaire FRS26R4A Side by Side...
Ice maker performing poorly only makes 1 or 2 loads per day
check to see if the line coming into the icemaker is frozen nor has ice building up in it if your getting water to the ice maker but its taking to long to drop them then replace the icemaker
Apr 29, 2010 | GE Profile PFSF6PK Bottom Freezer French...
LG LFX25980ST REFRIGERATOR W/BOTTOM FREEZER SHOWS MESSAGE ON DISPLAY ER IF WHAT DOES THIS MEAN
The control is not seeing a feedback signal from the ice room fan. (the fan inside the freezer which pushes cold air up to the in door icemaker) It is probably blocked with a build up of ice or frost, preventing the fan blade from turning.
Oct 20, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Refrigerator icemaker won't work and refrigerator fills with wate
check your fill tube you might have an ice build up on the end
the fill tube is where the water dumps into the ice machine
Oct 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
All water underneath.ice in the bottom.freezer working.not making
If I understand you correctly your water line that comes through the back wall of the freezer and into the icemaker is frozen. If so you have a bad water valve. When the valve goes bad it will not seal off the water. It will seep causing a slow drip where the water comes out at you icemaker. It'd slow enough to freez causing a ice blockage. This will not allow water to come through and fill your icemaker when it calls for water.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator ice getting all stuck together in one big piece looks like there is some water dripping in the ice box, I have changed the water...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
70 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
