Problem for Digital Cameras
Generic problem for all Digital Cameras
Samsung s1050 lockup problems
sometimes the camera locks up when taking a photo on auto setting. the image freezes on the lcd and nothing works, the camera also wont turn off the only way to rectify is to remove the batteries. Sometimes when taking a photo the red beam stays on and the camera locks up with no lcd.
Same Problem
Sep 01, 2008
-   my camera is stuck with the lense out and it makes a clicking noise and when I try to turn it on and the screen says "lense error"-
HelpMe3333 Aug 14, 2008
-   . the problem of my s1050 and the most common ... and that it freezes
sometimes when I try to use it without any possibility to interact but
to take away the batteries .... I tried to provide it with batteries
with higher amperage but having spent almost 18 pound for the 2450 mah
not served to .... I would be very grateful if I deste of straight
through L.
linofd Jun 24, 2008
-   My camera got struck with the lens open. I removed the batteries and placed again, but the camera is not working. When i switch on the camera the power gets on and display is not comming and lens not going back. and the power is also not switching off. -
rrb_ece Jun 14, 2008
-   The camera s1050 locks up after taking a photo, have to remove battery then place make in, some times have to enter the date again.
We also use AA battery but find we are taking about 15-30 photos than having to change them.-   Guest Apr 03, 2008
-   I tried to play back a video and it just froze. the power button would not work, i finally opened the battery compartment and loosened it just enough to turn the power off. it seems to be OK now.-
cydne
Solution #1
posted on Feb 06, 2008
Rank: Apprentice
Rating: 75%, 2 votes
Ended up exchanging the camera, due to suspected software problem within the camera, problem solved! exesive battery use solved by investing in 2790mh battery charger!
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
best for close up pictures for ebay
sony digital camera charger
will not turn on or power up
maxell 8mm MP 120 GX Metal
It jammed somehow...and maybe tape broke. I need to get all the...
(More)
It jammed somehow...and maybe tape broke. I need to get all the valuable memories from the tape onto DVD. In order to do that, first I need the tape cassette repaired. Can I mail it somewhere to have it repaired? Do you know the address? Thank you so much! You can reach me on my cell phone at (336) 830-3675.
when taking a picture a the display screen is black. no image is visible. when pushing the button to...
(More)
when taking a picture a the display screen is black. no image is visible. when pushing the button to take the picture the flash goes off, but no pic is available.
11 Other Users Have The Same Problem - Continued
Comment by PinchoPaxton, posted on Mar 18, 2008
Bought the camera.. inserted my brand new £7 Energizer Lithium batteries (Up to 650 photos).. it said that they were dead. Inserted the ones that came with the camera.. took 2 pictures, and the lense stopped moving. Couldn't turn the camera off with the power button. Removed batteries, inserted them.. camera dead. Sent off for a replacement.. Energizer Lithium dead, ones that came with the camera took 6 pictures.. dead.
Getting a completely different camera... on Samsung's own reccomendations.
Comment by wpayerl, posted on Mar 12, 2008
just got the Samsung s1050- having all the same lock up problems as described by others-freezing, batteries reading low and shutting off (with brand new batteries) etc.
C'mon Samsung- you are going to lose your reputation.
wpayerl@earthlink.net
Comment by Guest, posted on Feb 21, 2008
Samsung S1050 will lockup when taking a low light picture without flash in AUTO. Only way to reset is to remove batteries. Called Samsung support, "Diane" said I should use rechargable batteries and the problem should go away. I told her the problem occured even with fresh batteries. I suspect they have a software problem and either do not know about it or they are instructing their support personel to lie.
Comment by sunflex, posted on Feb 17, 2008
My problem is when i put in brand new batteries it says low battery and turns off. Its been doing that for a week now and never turns on. Guess i will have to return it to samsung.
Comment by ban031, posted on Feb 17, 2008
When power button is pressed the green power light comes on and the lens extends but no picture shows on the screen. The camera is frozen and no function can be made. When you take the batteries out the lights go off but the lens does not retract. When the batteries are replaced the green light comes on but again the camera is frozen. At present I can't get the lens to retract and the camera is inoperable.
Comment by Dave Legion, posted on Feb 15, 2008
from the outset the batteries supplied ran out after 20 minutes or so. Thenafter purchasing re chargables, even when left out of the camera when not in use, it would say low battery then turn off. Up side, i've taken 5 very nice pictures!!
