Question about HP Compaq nc6000 Notebook
Laptop wont start up
My laptop turns on for about 10 seconds the fan is on then it switches of when i turn it on i get a blue light
  • 1 more comment
  • Baby Antony Feb 26, 2008
    My HP Compaq Presario V6000 on switching on on indicators blue leds are lit. The fan is running, I could hear then it stops after a short while. Sreen remains blank. Tried pressing f2 and f8. also pressed ctrl alt del. still the screen remains blank. Is there problem with BIOS, reseating RAM will solve the probelm??or any other remedy. pl advise
  • strick1 Mar 14, 2008
    I press the power button. the Blue light and the fan turn on. Then after 5 seconds the third light in (amber color) on the left side comes on, then Lab top powers off after about 10 seconds.
  • midcest812 May 05, 2009
    my problem is that my laptop turns on and runs but after a short while my screen turns off, but my light stays on such as they keys light and the wireless light plus green light
I had the same problem. It is actually very common problem with the Maxin chip near the processor. The solder joins become cracked over time from the motherboard flexing when the lid is opened and closed.
A temp solution is to press down firmly with the palm of your hand around the F12 and leter P button areas. Make sure you do this with the laptop on a flat surface.
Bingo.. your laptop should then boot. However, moving the laptop may once again flex the motherboard and the unit will freeze again.
Good luck.
Posted on Mar 21, 2008
    Problem Solver:
  • 12 Answers
Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Good luck
I have the same problem. Its probably the hard disk on its way out. Back up your files just in case
Posted on Mar 16, 2008
    Novelist:
  • 123 Answers
Hi
The solution to your problem is probably not the monitor, follow these steps:
1. Connect and boot your computer with 2 different monitors.
2. If it does'nt work with either of them the problem is from another computer component.
Posible Problems:
1. Your video card may be damaged or moved from it's slot.
2. Your proccessor may be damaged.
Posible solutions:
1. If you have computer hardware knowledge open the case
2. Remove the Video card.
3. Insert it back or insert another video card from a friend.(if it works with your friends card, obviously the video card is the problem)
4. Restart your computer and see if it works.
Now if it does'nt work after that you will have to replace your proccessor with one that works, from a friend, because you say your computer boots but if your monitor doesn't work you don't know for sure if it boots corectly.
The steps above are only for people with hardware knowledge, if that is not your case you should contact a computer service.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 01, 2008
Acer aspire 5750 won't turn on
check you fan make sure its running,,some times if its not it wont let the laptop start.
Apr 16, 2014 | Acer Aspire Computers & Internet
My kobo wont turn on
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
2005 vw beetle overheating
My car overheated and began steaming so I pulled over.
The water was gone in a matter of seconds and I had refilled it the day before and so on. The blue ticking overheating sound starts on every time
The fan wont turn on and it was jump started in order to get it home quick.
The Ac wont turn on either that was the first problem that happened , the compressor is good because it was removed and manually checked
The transmission had been kind of like jumping on me for a while but I got used to it.
So far what has been replaced has been:
Fan Module Control
Air Condition pressure switch
Cooling fan control
thermal switch
Oct 20, 2012 | Cars & Trucks
Overheating
Fan Module Control
Cooling fan control
thermal switch
Oct 20, 2012 | 2005 Volkswagen New Beetle
Fan issue
Only way to know is look to see if fan is on (set will shut down almost instantly if any fan slows or shuts off--the fans are all being monitored.)
Apr 29, 2012 | JVC HD-52G787 52" Projection Television
When turned on, no lights turn on but fan spins for aproximatly 10 seconds then stops Laptop wont turn on
the problem is with your power unit in your laptop.dont turn it on. take to the service, there must be some circuit problem, changing the circuit will surely solve your problem,,, thank you.. plz rate me,,,
Jun 29, 2009 | HP Compaq nc6000 Notebook
Will not turn on
Hi
do one thing remove the battery from the notebook and unplug the power cable press and hold the power button on the laptop for 10 to 15 seconds. connect the battery and power , turn on the notebook, it should work
Good luck
May 25, 2008 | Gateway Solo 5300 Notebook
HP Compaq nc6000 Notebook Logo
269 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
