Question about Proscan PS27500 27" TV
Panasonic CT-20SX12D 20" TV with Tau PureFlat Screen
My tv won't turn on manually or by remote. I had the 3 year extended warranty but it expired 12 days past the warranty. I never had any problems until 2 days ago. What can I do? What is wrong? Can I get parts?
Thanks
  • john107 Feb 04, 2008
    thanks very much for the advice. can I tell just by looking at the fuse that it is blown? what do I look for?
    thanks again
    Scholar:
  • 84 Answers
It can be a blown fuse inside. if you are handy you can try to open the tv and look for the fuse.check also if the
electrical outlet is working
good luck
wg
Posted on Feb 01, 2008
  • wilson garcia Feb 05, 2008
    yes
    it may look like a fuse like in a car charger for a cell phone,.about an inch long [.all tv's maybe different] pull it out. it's wedged between 2 prongs.look thru it in the light, and see if the stem inside is broken. if it is, then it's blown.caution some fuses maybe soldered to the prongs. use a flashlight to see thru it. there should be a amp size on the side.
    let me know how it goes
    wg
24" Panasonic Tau... about 9
Tv is old the tv CRT-(tv tube) it CRT Yoking circuitry not good as before.The tv deguassing coil in not eleminating all the interference of the tv functions anymore.Move the tv unit to the right or to left like about 3 or 4 inches either sides will help for this problems.
Apr 18, 2011 | Panasonic CT-24SL13 24" TV
I have 36" Panasonic CT-36SX12 TAU series. I had it repaired less than 3 years ago .and the same problem happened again As soon as turned the TV off it wouldn't turn back on .I was told this was the...
I would check the remote control by taking it out of the room first. If that is not the problem, it is likely to be a dry joint in the power supply that is "arcing" and causing this problem.
Re soldering the heavy components on the power supply board may fix it.
WATCH OUT FOR CHARGED UP CAPACITORS - THEY ARE LETHAL WHEN CHARGED!
Oct 16, 2010 | Panasonic CT-36SX12 36" TV
Panasonic CT-27SL15 has scan lines on top 4 inches of screen, what is problem and how to fix?
Nov 2011 - Comment
Have similar problem on a Panasonic Tau model CT-27SL15.
It's a 27" CRT TV manufactured around 2005.
Other posts / solutions on this problem say possibly a capacitor going bad in the vertical circuitry / near the vertical IC / vertical blanking circuitry. Telephone call to a TV repair person mentioned something similar - "possibly a bad capacitor in the vertical circuitry".
Found a service manual online w/schematics and board layouts.
Panasonic Service Manual
http://dl.dropbox.com/u/35219914/PANASONIC%20CT27SL15.pdf
See pg 25 (of 42) - Deflection Schematic Diagram (Main PCB)
Shows: V Output IC - IC401
Finding the actual bad component(s) may not be so easy.
Anyway ... just wanted to add this comment.
Feb 11, 2010 | Panasonic CT-27SL15 27" TV
Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Remote control
Did you try universal remote control. Are you sure remote control is good. http://www.retrevo.com/support/Panasonic-CT-20SX12D-TVs-manual/id/274ci956/t/2/
You can order in www.tritronicsinc.com Thank you
Aug 13, 2008 | Panasonic CT-20SX12D 20" TV
Panasonic tv old model
curve picture and auto shutdown
May 10, 2008 | Panasonic CT-20D11 20" TV
TV does not power up
Check Power Cord is Plugged into Active Outlet
Adjust Brightness and Audio Controls Change Channel Check Cable Connections Program the Remote Control Again Check Second Video Source Operation As warranty has expired, check if fuse at power supply input is ok.
Consult online manual for troubleshooting.
http://www.fixya.com/support/p232673-panasonic_ct_36sl13_32_tv/manual-7023/page-22
Feb 14, 2008 | Panasonic CT-36SL13 32" TV
My Panasonic CT-36SX31 picture has an hour shape
Take a look around (say, within 12 feet of) the TV... anything that can generate an electrical field? Microwave... refridgerator... old school stereo speakers...
Pin cushioned is a term applied to a picture that's doing what you described. Adjustments to correct that are typically found in computer monitors.
I have an identical television to yours and that adjustment isn't available. You could try degausing, but I doubt that works.
Jan 27, 2008 | Panasonic CT-36SX31 36" TV
CT32SX12F 32" Won't power on
when mine it, i had to replace a fuse
Jan 05, 2008 | Panasonic CT-32G11 32" TV
Proscan PS27500 27" TV Logo
153 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
