Question about Brother DCP-7020 All-In-One Laser Printer
DCP-7020 start up confusion!!
Well my problem is that i recently bought a DCP 7020 brother copier-printer-scanner from somebody and realised there were no plugs for it so now im stuck with this and no way to work it? would i be abel to buy the power cords it needs in the store? dose it requier a cd or anything...please need your help!
thanx sarah!
    Novelist:
  • 171 Answers
Yes, you can get the power cord and the USB cable from any electronics store. For the USB cable, get one that is an "A-B" cable, e.g. the cable with a square head on one end and a rectangular head on the other.
The power cable should be a standard 120v cable with male pins on one end (that go into the outlet) and female on the other (that go int othe printer. A used computer store would have lots of those they'll sell you for pretty cheap.
You will need drivers and software to use the printer. This normally comes on a CD, but you can also download it online.
http://drivers.softpedia.com/progDownload/Brother-DCP-Full-DriverampSoftware-Package-Download-19399.html
Posted on Feb 01, 2008
6ya staff
SOURCE:
How to replace paper feeding kit on DCP 7020
Most likely all you need is to clean the rubber feed rollers. Use alcohol.
Oct 24, 2014 | Brother Industries, Ltd DCP-7020 Laser...
Why won't Brother DCP 7020 Scanner connect to computer?
Try opening the Scan function from the computer and pull it from the MFP printer instead of being at the scanner trying to push it to the computer. Your Brother DCP 7020 would have to be on the same network and installed on the computer you are trying to use. Check your usb cable, Ethernet cable or if wireless - check the Wi-Fi connection settings (network name and correct passphrase).
Aug 30, 2014 | Brother Dcp-7020 All-in-one Laser...
Replacing pick up roller
you can safely replace the pickup roller without stabilising the document scanner and the laser scanner.
replacing the pickup roller is a relatively simple job that is easily done by someone who is good with their hands or with a little common sense.
here is a video showing the procedure
and a link to buy the part
Mar 28, 2014 | Brother DCP-7020 All-In-One Laser Printer
I have a brother DCP-7020, I recently changed the Toner, and the printer still thinks the Toner is out, when it's brand new and full. I have restarted & disconnected the printer to no avail, any...
There seems to be a semi-magic routine to reset the toner counter on the DCP 7020. It is, I quote,
"Open the front cover.
Press options button.
Press the start button.
Press + or up arrow button 10 times.
Press set button.".
This ought to be done with a "pause" of 2-3 seconds (between keys, I'd think) to avoid the system resetting and having to start over.
Nov 04, 2009 | Brother DCP-7020 All-In-One Laser Printer
The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Oct 12, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 Scanner Lock Problem
According to Brother there is no switch for this model, you can just power off and on again. Sounds like it needs to go into the shop.
Jun 25, 2009 | Brother DCP-7020 All-In-One Laser Printer
DCP 7020 cartridge
wrong cart or did not remove packing, make sure u use oem product
Dec 29, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
103 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
