Question about EliteGroup K8M800-M2 Motherboard
ECS K8M800 bios can't detect hd pata seagate
My mobo ECS K8M800 bios can't detect hd pata seagate st380215a 80 gb, I use a pata with 10gb of seagate together with dvd recorder and a cd recorder,
sometimes, the hd 80gd is recognized by the bios, when it's alone, but with the 98 boot disk the fdisk catn' find the hd.
I have tried as master and slave and nothing.
  • leogvt Feb 01, 2008
    I have tried all positions with the jumpers
  • Dr_Roger May 10, 2008
    I have a Wintergreen machine that was equipped with a Linux OS. I
    trashed Linux and installed Win 2000 and later upgraded to XP
    Pro. Worked beautifully until the Wireless Router failed and 127
    invaders played havoc with my machine. Backed up files and tried
    to reinstalled XP. After files installed, the machine rebotted
    and would not complete the installation but rebotted and started the
    install process over again.
    Check into BIOS, the HD was not being recognized. Had the HD
    tested and they said it was dead. Purchased a new WD 320
    drive. I am having the same problem in that BIOS recognizes
    the drive but tells me that BIOS is off for that drive.
    I cannot find anything in BIOS that turns on or off BIOS access to the drive.
    Can you help?
    Dr. Roger
Fixed.
The problem is that the source was on 220 volts, I've turned to 110 and voi'la. It's working fine.
Thanx.
Posted on Feb 02, 2008
How you setting the jumper, pls refer to mobo manual book or HDD or your DVD/CD recorder. i gues your problem is in setting the jumper. thx
Posted on Feb 01, 2008
  • BlackMobo Feb 02, 2008
    i don't know how you try to setting the jumper(cause you are not tell clearly here), if the problem is with the mobo, when you put alone the 80gb hdd may be you won't detect it.
    from your description i assume that you have four drive(1. Hdd 80gb, 2. hdd 40gb, 3. DVD recorder and CD recorder) isn't it? ok if so,
    #1. try to install just HDD 80gb and hdd 40gb first, sett the jumper to Primary and
    secondary Master, it's up to you whether 80gb or 40gb that is the master. if it's
    detected with the bios, usually it will detected with the fdisk too., then try to install
    the DVD and CD Recorder to Primary and Secondary slave.
    thx
Pata slave drive not found in bios a05 of dell dimension 8400 but found in windows and linux os's
Hi
Have you tried swapping the pata drives - eg master to slave and vice versa ?. I have found that if the drives are not from the same manufacturer, quite often, you cannot get both drives to work. Seagate and WD normally are O.K., but some of the older Fujitsu ones just knock out any other drives on the same 40/80 way cable.
Mar 17, 2017 | Dell Dimension 8400 PC Desktop
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
I need manual instructions for instalation of K8M800-M2 Motherboard
go to ecs.com elitegroup or google K8M800-M2 THEN SELECT ECS SITE mobo drivers bios and manual all available
Dec 15, 2009 | EliteGroup K8M800-M2 Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Ecs elitegroup P4M266a-8235 lost driver
Download a Program called ( Driver Scanner ) from Rapidshare.com
and it will find every driver at your Computer
Jan 10, 2009 | Computers & Internet
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
New hard drive 160 GB ATA can't be partitioned
why dont you try 40000 in the first partitioned..if doesn't work.. try fix your hard drive using a seatools, a bootable disk, that can detect and repair a bad sector for a hard drive..
Feb 26, 2008 | Computers & Internet
My PC can't detect my harddrive and rom! plss someone help me:(
check your system bios settings on your computer (F11,ESK or DEL on startup) try to autodetect harddisks and see what it says
Nov 06, 2007 | Seagate (ST380011A) 80 GB IDE Hard Drive
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
EliteGroup K8M800-M2 Motherboard Logo
377 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
