Question about IBM ThinkPad G40 Notebook
Startup problem With thinkpad g40 and xp: I shutdown last night by (accidentally) shutting down windows. Now when I attempt startup I either get a blank screen or windows starts up and progresses to where the wallpaper background displays...then nothing.
  • 758 Answers
I would recommend you to boot your system and safe mode and do a system restore...To open your computer and safe mode hit the F8 button on your keyboad when the computer is booting up..click safe mode..and then once you get to safe mode its going to give you an option to restore your computer to another day..after the restore is finish, you should be able to use the computer without any problems...
Posted on Jan 31, 2008
6ya staff
SOURCE:
Thinkpad hungup on shutting down
Pull the AC plug, remove battery. You may want to do a System clean-up. I assume you have Windows 7? Use two freeware programs to assist you. 1, CCLEANER: http://www.filehippo.com/download_ccleaner/ This freeware program will clean the junk from your machine, in the TOOLS section, select STARTUP, disable ALL unnecessary startup programs, this will speedup starts, shutdowns and running. 2, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, run a FULL scan, delete ALL results, reboot. Here are more tips to speedup Windows 7: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332
Apr 04, 2013 | Lenovo ThinkPad T410 Notebook
Attaching to network with wireless card using WPA security
1-Start -> Run
2-
Type in services.msc
3-
Click the OK button
4- Scroll down to Wireless Zero Configuration and select it.
5-You now have the option to Start the service. You also need to change the Startup Type from Manual to Automatic
Action -> Properties
6-
Click OK.
You can now use XP to manage your wireless connection.
Jun 28, 2012 | IBM ThinkPad G40 2388 Notebook
Thinkpad T61 went dark abruptly after startup
Make system restore, or better reinstal vista from IBM image file, dont install any updates, go get windows 7 , and get rid out of vista.
Oct 31, 2009 | Lenovo ThinkPad T61 Notebook
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
Windows xp startup and shutdown has changed!
To configure Windows XP to use the default logon and shutdown screens for every logon session, follow these steps:
  1. Click Start, and then click Control Panel.
  2. Double-click User Accounts.
  3. Click Change the way users log on or off.
  4. check the Use the Welcome screen check box.
Thanks
proton
Apr 04, 2009 | Microsoft Windows XP Home Edition
I have Dell inspiron 1420, but my laptop starts & shutdown very slowely
hmm that means there are lot of service is running in your computer...try this for starts-
1)open run command
2)type msconfig in run.
3) uncheck all unnecessary program at startup tab then restart system.
now for shutdown pc
try this
1) open run command
2)type regedit
3) search waitforkill registry using ctrl f.
4) increse value of waitforkill like 200 to 20000.
Mar 29, 2009 | IBM ThinkPad T30 2366 Notebook
My laptop doesn't shutdown
Dec 23, 2008 | Lenovo ThinkPad R500 Notebook
PC SHUTS DOWN MONITOR AND FAN
Hi Brandy19960,
Thanks for the posting in FIXYA.
Please do the following steps:
Step – 1
Right-click on My Computer, open Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” Uncheck the box in front of “Automatically restart.”
Step - 2
To change the setting, click Start --> Run--> type GPEDIT.MSC, click OK.
Drill down to Computer Configuration | Windows Settings | Security Settings | Local Policies | Security Options.
In the right pane, find “Shutdown: Clear Virtual Memory Pagefile.”
NOTE: Since someone actually has to have set this policy, the problem will be pretty rare, but is worth mentioning. However, Forum participant “roadrunner” reported that the personal security app Privacy Eraser automatically enables “Clear virtual memory pagefile,” and, therefore, may be the cause of a slow shutdown.
Step - 3
When Windows XP won’t powerdown automatically, the APM/NT Legacy Power Node may not be enabled. To enable this, right-click on the My Computer icon, click Properties | Hardware | Device Manager | View. Check the box labeled “Show Hidden Devices.” If it’s available on your computer, there will be a red X on the APM/NT Legacy Node. Try enabling it and see if this resolves the powerdown problem (Tip from Terri Stratton). Or, to check the other side of the APM/ACPI coin, open the Power Options applet in Control Panel. If there is an APM tab, make sure the “Enable Advanced Power Management Support” box is checked.
Step - 4
Try a Shutdown shortcut -
For a shortcut to RESTART Windows XP:
SHUTDOWN -r -t 01
For a shortcut to SHUT DOWN Windows XP:
SHUTDOWN -s -t 01
Step 5
WORK-AROUND: Disable power management for your USB hub: Open Device Manager (click Start, click Run, type DEVMGMT.MSC, click OK). Double-click to expand Universal Serial Bus Controllers. Double-click USB Root Hub. Click Power Management. Uncheck the box “Allow the computer to turn off this device to save power.” OK your way out
Step – 6
Click on the Start button.
Select Run from the menu.
In the run dialog box type “msconfig”.
Click OK.
Once in the msconfig utility select the startup tab. In the startup tab you will see several programs listed with a checkbox beside it. If there is a check mark beside the application listed, the application will startup when your computer starts up.
Regards
ELLIN
Sep 13, 2008 | Microsoft Windows XP Home Edition
Thinkpad T61 shutsown problem after installaing XP pro
Getting into Windows Safe Mode when you cannot boot after installing a new device or driver. ... From Windows Safe Mode click Start / Shutdown and restart the computer.
NTLDR is missing If you are attempting to install Windows XP or Windows 2000 and are receiving ... After the above two files have been copied, remove the floppy diskette .
How to shut down / restart the computer with a batch file. It may be necessary after a batch file is completed its copying or installing ... Microsoft Windows XP includes a new shutdown command that will enable .
Read and follow instructions/Good Luck, Please dont for get to Vote/Thank You.
Dec 08, 2007 | Lenovo ThinkPad T61 Notebook
IBM ThinkPad G40 Notebook Logo
152 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
