Question about Canon PowerShot A95 Digital Camera
A95 PowerShot turns on and off until batteries die.
This A95 has a mind of its own.... with fresh batteries, it will turn itself on, then a few seconds later, off, then a bit later, on, and so on, until the batteries are dead. If it's turned on manually, then in a few seconds, it will turn off, then a bit later, will turn on, and so on, until the batteries die. I have to leave the battery cover open to keep the batteries from dying. If it is on, occasionally, I can take a picture, before it turns itself off.
  • keith20mm Feb 01, 2008
    By the way, were you the person that left a similar comment on my blog"
    No, this is the only post on the A95, and I'll certainly disassemble the camera now that I have a lead. Thanks!!
    k
    I found the problem with the A95, and it's a service center repair job. The keypad matrix ribbon connector LATCH at the mainboard has a broken finger on the right side. Therefore, the ribbon contacts are not firmly seated to the mpu connector pads, and are making intermittent connection to the mpu, and doubtless causing all kinds of problems in the programs keypad matrix scan routine. I also located the little black plastic finger rattling around inside the case.
    Although I have surface mount equipment (hot air soldering/desoldering equipment), it isn't worth my time to persue this repair... I'll let Canon handle it from here, and if the cost is prohibitive (they will likely call for a new main board, even though the problem is their poor choice of a ribbon connector, and, after all, the problem is JUST A BAD CONNECTOR, .. rather than attempt a surface mount connector removal/replacement) then I'll just pitch the unit, wait for a dud to show up that needs a part other than the main board, etc, or just buy a newer model camera...
    Thanks for all your help...
    keith
  • Canon Master
  • 4,738 Answers
Sounds like you have a stuck power button or shorted power switch. To repair you'll need to remove the top cover. Please see the following disassembly guide. It's in Estonian, but you can follow the pictures.
Continue to page 2, paying particular attention to the second and third picture. It looks like the power switch is connected to the camera through a simple ribbon cable. I'd suggest removing the ribbon cable end from its connector, cleaning any obvious crud, and then reseating the ribbon cable end into its connector. Ribbon cables are notorius for suddenly shorting or getting a bad connection at the connector. Usually just jiggling the cable can fix it too :-) Good luck!
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
By the way, were you the person that left a similar comment on my blog? http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
Posted on Feb 01, 2008
  • CameraR
    CameraR Feb 01, 2008
    Looking at the photos, appears that you'll need to remove the top left screw, along with several screws that you'll need to access through the battery compartment. A magnetized hobby screwdriver would be ideal for the hard to get at screws.
  • CameraR
    One more by the way, don't go any further than popping the top as there is a risk of electrical shock from the flash capacitor:
    http://camerarepair.blogspot.com/2007/11...
I turned the camera on and saw a black screen that moved when I did. I replaced the batteries with fresh ones no good I installed the memory full 32mb mem card and it worked, I reinstalled the 512 mb mem...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Apr 03, 2010 | Canon PowerShot A95 Digital Camera
Canon PowerShot A95 is using up batteries too fast
My experience seems to show that it's not your camera as much as it is that batteries (AA type cells) don't have the "juice" they used to have. Try using the Energizer Ultimate Lithium AA batteries. I've turned many of my customers on to them, and they swear by them!
Feb 26, 2010 | Canon PowerShot A95 Digital Camera
Canon A95 Cannot be switched off
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Jul 05, 2009 | Canon PowerShot A95 Digital Camera
A95 pictures are grainy with horiz lines, camera makes clicking s
Contact Cannon tech support. A95 has a sensor problem. If it is the sensor Cannon will pay shipping both ways and repair it for FREE.
Dec 27, 2008 | Canon PowerShot A95 Digital Camera
My canon A95 comes on and goes off after few seconds.
Try to reset your camera using a command in the set up menu. An error message followed by turning itself off, usually means lens jam. Replace the lens.
Nov 12, 2008 | Canon PowerShot A95 Digital Camera
Camera refuses to zoom out
I had a similar problem. The lense extended when I turned the camera on and immediately retracted and turned off by itself. I pulled the memory card and then reinserted/reseated it. It appears to have fixed my problem.
Apr 29, 2008 | Canon PowerShot A95 Digital Camera
Will not work at all
problem with the contact of the battery probably. check and may be try to wash it with coton buds and a little bit of alcohol.
bye
Apr 22, 2008 | Canon PowerShot A95 Digital Camera
Canon A95 "Change Batteries" problem!
You need to use 2100 mAH or 2300 mAh rechargeable batteries - alkaline batteries will not maintain the high level of power required.
Aug 06, 2017 | Canon PowerShot A95 Digital Camera
Unable to turn on my Canon Powershot A95 camera.
Here are some simple things to try first for a camera that won't power on:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Nov 01, 2007 | Canon PowerShot A95 Digital Camera
Canon PowerShot A95 Digital Camera Logo
178 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
