Question about Yamaha RX-V730 Receiver
Yamaha RAV213 remote
I have the Yamaha Yamaha RX-V730 6.1 Channels Receiver and the
RAV 213 remote control. For some reason, i now cannot access the power on/off, volume and other functions. I can just about change the inputs. Can someone please tell me how to program the remote back to this a/v please.
5 Suggested Answers
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
lynchms
  • 93 Answers
SOURCE: yamaha rx v663 receiver, turntable input
What you will need is a phono pre-amp, then you can run into the receiver with a line level input to an empty audio input on the receiver, you can try Radio Shack to obtain one.
Posted on Feb 11, 2009
SOURCE: zune and yamaha RX-V663 Receiver
Buy the Zune A/V kit and hook it up to a non used rca port on the back. Look for the older ones for the 30 gb units, they are much cheaper than the new ones and it takes 10 seconds to modify them to use on the newer units. The A/V kit has 3 rca plugs, one for sound and 2 for video. If you pick a source that can play video and sound on your receiver, then the screen on the zune will display on your television. The A/V kit has a remote with it also so you can control the zune from the room. I have not tried it, but since the Zune remote is IR then if you have a good all in one remote, such as a harmony, you may be able to program the codes from the Zune remote into it and even be able to control your stereo and Zune from one remote. Hope this helps.
Posted on Feb 28, 2009
hbsurfdawg
  • 95 Answers
SOURCE: Yamaha RX-V1400 receiver powers off, in case it becomes louder
Hey, yeah that can be frustrating.
When you turn it up do you hear the relay or a clicking sound, then you turn it on and it comes back below the +2db?
Try unplugging All the speaker wires from the unit. Turn on the unit and listen for the click.
after the click, turn it up past the 2+ db mark and see if you hear it click or shut down. If it did not click off, then suspect a shorted crossover on one of your speakers.
2nd test is to plug in One speaker, and test it at high volume, it will not harm it. If it shuts off disconnect that speaker and try another. Only one at a time.
If it works at high volume, you need to isolate one of your speakers and i bet it has a shorted crossover that has been cooked. P.S. If one is bad, suspect they will fail at a later date.
If they all fail, use a friends speaker and try it before sending it to a repair shop.
P.S. i found one on ebay i think you can get for under $100 bucks in the box.
http://cgi.ebay.com/Yamaha-RX-V1400-7-1-THX-Select-Receiver-MINT-Condition_W0QQitemZ330311512027QQcmdZViewItemQQptZReceivers_Tuners?hash=item330311512027&_trksid=p3286.c0.m14&_trkparms=72%3A570|66%3A2|65%3A12|39%3A2|240%3A1318
E
Posted on Mar 02, 2009
Have Yamaha RX-V363 with remote RAV 284 not able to find code for Panasonic Blu-ray DMR-BW750 or LG 47HDLED-LCD known as 47LH90QD, help please. David
chances are that the yamaha rxv363 will not control the bluray since it was produced before the bluray. as far as the LG codes, you may want to try a Zenith codeset. they are similar.
Feb 23, 2010 | Yamaha RX-V363 Receiver
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
How to code TV into Yamaha RAV290 remote
You have to assign the tv code to one of the components such as AV1 or Audio 1. If you have to separate the audio from the video channels then you need to go to the yamaha website and look at the firmware update manual from august 2009. It tells exactly how to do this.
Jun 20, 2009 | Yamaha RAV-300 Remote Control
Remot control dont working
dropping to a hard floor is always the reason when remote dont work.change the transmiter led or check some crack inside.clean the board and the rubber button with alcohol.
Oct 21, 2008 | Yamaha RX-V420 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Feb 04, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V730 Receiver Logo
828 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
