Question about Logitech MX Revolution 931689 Mouse
Mx revolution mouse
It just stopped working, for no reason. It still lights up normally, but it wont work!
  • Anonymous Jun 29, 2008
    Oh man, I have the same problem. The mouse is recognized and it lights up when moved, but the cursor wont move, and none of the buttons work.
You have to download the reconnect software from logitech and follow the directions. Sometimes they lose their connection from the reciever.
Posted on Sep 27, 2008
  • 28 Answers
Make sure it's clean where the light sensor is. Dustbust it or something. otherwise I'd say it's dead.
Posted on Jan 31, 2008
6ya staff
SOURCE:
Logitech mx revolution
Hi
Maybe your registry is not clean. You can use registry fixing software and then run registry analyze. and restart your computer.
Jan 19, 2014 | Logitech MX Revolution 931689 Mouse
Mouse will not charge when put in the base
I have a very bad solution about this, but it works on my mouse that also doesn't work. Try to put a tiny bit of water ( or spit Oo ) on the little, usually copper, receivers on the mouse. That makes for a better contact. Just get your finger wet and touch those receivers.
May 15, 2010 | Computers & Internet
My right click mouse button stops working periodically any suggestions how to stop this from happening
Sage, The mouse may be fine. What may have happened is that the lever that you press as right click has a micro switch below it. This micro gets pressed and you get a right click. As time passes the gap between the lever and the switch increases and you have to click harder and then comes a time when this contact can not be made under normal circumstances. So place your finger in a different position so that the lever is pressed differently. You may still get a few thousand clicks before even this stops working.
Basically, the bottom line is that the mouse is getting old and needs replacement.
Dec 06, 2009 | Logitech Cordless Desktop MX 5500...
Back button, forward button does not work on my mx revolution mouse
Problem was solved by remove usb connection and reconnecting. All buttons work now. Thanks
Nov 03, 2009 | Logitech MX Revolution Wireless Laser...
Need to replace the battery in a Logitech MX Revolution Mouse
Hello. Yes, it is quite simple to remove the battery of a Logitech MX Revolution mouse yet for some reason when going through the Logitech product support website it states that it is not possible. Just remove the 4 teflon pads located on the bottom of the mouse and then remove the four screws located under the pads. Once this is done turn the mouse back upright and remove the top off of the mouse. I would suggest temporarily removing the flex cable that holds the top and bottom of the mouse together. There is a small metal clip that holds the battery in place that must now be removed.
NOW FOR THE VERY IMPORTANT PART. There are two different generations of the Logitech MX Revolution mouse which have different batteries. The first Generation uses the L-LY11 battery and the newer generation of the MX Revolution uses the L-LL11 battery. There is no way to tell which battery your mouse uses without first opening up the mouse. Once opened you can easily tell which battery your mouse uses. Here is a link to a site that shows you an example of the L-LY11 battery: MX Revolution L-LY11 Battery
Here is a link to a site that shows you an example of the L-LL11 battery: L-LL11 Battery for Logitech MX Revolution Mouse
As you can see the L-LY11 battery has wires and a plastic connector and the L-LL11 battery has contacts. You should definitely determine which battery your mouse uses ahead of time to eliminate any frustration caused by ordering the wrong battery ahead of time.
Sep 12, 2009 | Logitech MX Revolution Wireless Laser...
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mar 23, 2009 | Logitech Cordless Desktop MX 5500...
New mouse wont connect....
This is a common problem, go to the Logitech website (www.logitech.com) and download the Reconnect utility. Follow the steps given to you in the software and it should work fine! If not, is the mouse fully charged?
Nov 10, 2008 | Logitech MX Revolution 931689 Mouse
Battery
Not sure how your mouse is configured but will give you two possibilities to use.
Turn your mouse over and see if there is a small door on the bottom where the batteries are located.
Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
Hope this helps. Bud
Aug 21, 2008 | Logitech MX Revolution Mouse
Logitech MX Revolution 931689 Mouse Logo
487 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Alun Cox
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
