Question about Mitsubishi WS-55809 55" Rear Projection Television
When Turned on Picture curved at top and bottom
When i turn the unit on the picture curves down at the top and curves up at the bottom. After a few minutes it goes away and occationally comes back when changing channels or on commercials, kind of randomly but not, if that makes any sense. You can see the red, green and blue colors a bit too. Had someone come out and quote $365, but that was a few months ago and don't have the quote and don't remember what it needed. I do remember him saying if I leave it and don't fix it now that it will cost more cause the projectors will need to be replaced then. Thanks in advance.
  • 1 more comment
  • joelcord Jan 31, 2008
    what exactly does that part look like?
    Thanks a lot, man. I'll try it out and let you know if I need your expertise again, my friend. Appreciate it!
  • Anonymous Feb 21, 2008
    Having identical problem...told the module may need to be replaced. Can I do that myself & what module is it?
Paid $240 to fix issue. Tech soldered IC's 8C01, 8C02ON. Convergence board adjusted align. This happened within a short period owning TV. No more Mitsubishis. Customer Service at Mitsubishi is crap!
Posted on Feb 18, 2008
  • Mitsubishi Master
  • 8,617 Answers
I would try soldering your convergence amp ICs. Mitsubishi has had some issues with sparse solder at the ICs Dress up the solder a bit and see if this helps. If not you will no doubt need to replace the ICs there are two of them and they cost about 10.00 each. Let me know if you need anything further.
Posted on Jan 31, 2008
  • Sonny Berry
    Sonny Berry Jan 31, 2008
    if you go to the following link they have a picture of a convergence IC STK730-150 Those are not the same numbers in you set but they look identical. Yours are attached to a large aluminum heat sink.
  • Sonny Berry
    Youre welcome. Just let me know if ya need any more info.
Curved picture at top and bottom
if it is bowing from top and bottom your looking at a convergance problem if you keep using your tv soon there will be no picture at all when the board crashes... convergance board needs to be replaced... hope this helps..
Apr 11, 2009 | Samsung HCN4727W 47" Rear Projection...
My samsung cr32z30 32" hdtv turns off automatically after running for about 30min to an hour. also the picture is curved on both sides when watching tv in 4:3 ratio. the curve is most prodominate at...
Linearity coil (there are several) shorted causing HV to increase and causing HVSD, no replacement parts available. Replace sweep module to fix.
Nov 10, 2008 | Samsung Televison & Video
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Curved picture
ur problems is on the pincushion check for a capacitor that its bad on the pincusion section  good luck.
Nov 01, 2007 | Televison & Video
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Three curved lines have appeared approx. 6" up from the bottom of the screen. Is this a simple fix .... maybe as simple as replacing a bulb?
Are you saying that the whole picture is gone and all you see on the screen are 3 curved lines near the bottom, or is the picture there but 3 curved lines are over the picture, or is the picture there but the bottom of the picture has curved upeards?
Aug 23, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Rca 52 inch keeps shutting off and picture is curved
The curved picture indicates failing parts in the pin amp section and probably some faulty parts in the scan amplifier sections. The set is being turned off by the uPC because there is a fault indicated, and it is going in to protect mode.
The set will have to be properly serviced.
Jerry G.
Aug 21, 2007 | RCA 32V420T 32" TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
