Question about Vizio GV42L 42 in. LCD Television
Vizio "no signal"
Just bought a new 32" Vizio hdl tv. Trying to program it. Got "no signal". Help!
  • Anonymous Mar 01, 2008
    Our Vizio just went to blue screen and no signal display and shuts off.
    We've had it for a year and this is the 1st time it's done this. Any body know anything?
  • gsmb Dec 01, 2008
    Our 42" Vizio works fine most of the day, then in the evening, around 7 -9pm we get 'no signal' on a blue screen. The other tv's (analog) that receive from the same dish work fine. We use Dish satellite. It also gets a rolling screen and fuzzy reception just prior to going out. My nephew said digital tv's should not have a 'rolling screen' problem. Very puzzling! No warranty. Model VX42L,
We just had this problem and it was the cable that came with the set. Once we replace this, it received a picture, however, now the volume and on/off does not work on the Verizon remote.
Posted on Mar 09, 2008
6ya staff
SOURCE:
Hi I have acer laptop, I have a cable one end is hdmi and the other side rgb, is there a down load driver so it will work. thank you
If you're trying to display output from the laptop to the Vizio you'd be better off using an HDMI to HDMI cable. The VGA port on the Vizio E320 only supports 640x480 resolution; you have to set your display output accordingly, usually in control panel. Using HDMI you're able to keep the signal HD, @720p. The E320 also supports 1080i, but you're not going to see all 1080 lines. If for some reason you're trying to go from the Vizio to the laptop it just doesn't work that way.
Jun 24, 2014 | Vizio E320VP 32" LCD TV
My tv remote is not working, I bought a universal remote and still not working. I programmed the new remote to my Sony tv and it worked fine. I beleive is the tv itself, any sugestions? Thanks for the...
there may be an issue with the ir sensor board in the tv. you could use you serial number and model number to research the part to replace (rather inexpenisve part) or have a vizio certified repair company diagnose the issue and theyll replace the board for you.
Nov 20, 2010 | Vizio L32 32 in. LCD HDTV
JUST BOUGHT TV NO SIGNAL need help
Reset the tv and the cable box by unplug,replug it an hour later.Ur tv and cable box should reboot it self.The tv signal should return and work again.Not,call ur tv warrenty service for the repair.Tv under a year old,still have warrenty.
Jul 11, 2010 | Vizio VW32L 32 in. LCD HDTV
Remote code Directv
try vizio under tv tv brand in the direct tv remote control codes.
Aug 02, 2009 | Honeywell CE2Y-PPT Remote Control
Register a 32 inch Vizio Tv
go to www.vizio.com. select the support and go down to the register your vizio. Fill out the require field and press submit. this will get your TV register.
Jun 16, 2009 | Vizio VW32L 32 in. LCD HDTV
DTV signal will not come up on start up but after warm up
Was just the DTV card replaced only or the mainboard? Replacing the entire mainboard should do the trick.
May 22, 2009 | Vizio L32 32 in. LCD HDTV
Vizio remote control not working
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Code for Vizio tv
It looks like your remote takes a 4 digit code. Try the following codes:
Vizio 0891, 0912,1783
Feb 27, 2009 | Vizio VW37L 37 in. LCD HDTV
Vizio p42 type sp42a nov 2004 hd tv
POWER SUPPLY OR LCD PANEL INVERTER BOARDS . AVAILABLE THROUGH VIZIO , PARTSTORE.COM OR EBAY
May 14, 2008 | Vizio L32 32 in. LCD HDTV
Vizio tv
i used the goldstar codes on my vizio tv and it worked
heres a list of codes
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, 172, 196
the code 004 worked on my 32' Vizio HDTV, for the Jumbo Universal Remote
Nov 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio GV42L 42 in. LCD Television Logo
1,015 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
