Question about Vizio L37 Television
L37 tv turns off on own and then will not turn back on
My L37 Vizio turned off on its own while watching the news and now it will not turn back on. The amber light is on (normally meaning tv is off), so it is recieving power. I have unplugged the tv and changed outlets on power strip, but the tv will still not turn on. vizio states i need to have it repaired, but warranty is out.
could it just be the power supply, or do i have a bigger issue?
  • Anonymous Apr 01, 2008
    My Dad's TV had exactly the same problem.
    The LED glows amber, never turns green, and whole set is dead.
    I too replaced the power supply, but the problem still persists.
    Now I am looking at 2 boards, the "LCD controller board", which has most of the video I/O, and underneath it is a smaller controller board, "Video Box Board Assembly", which has a single tuner input and an ARM CPU. Either board is over $200.00, so hoping to get the right one before proceeding further.
  • Anonymous Feb 12, 2009
    How do I fix this problem and what will it cost.
  • 6 Answers
I just did a troubleshooting session with Vizio as my Vizio will not turn on unless I unplug iy, wait about 10 seconds and plug it back in. This is getting worse as time goes by! The tech made me do a master reset and so far so good! Hold the on/off button in while TV is off for 30 seconds and then try it!
Posted on Dec 26, 2011
    Problem Solver:
  • 12 Answers
I have same problem and i put in a new power supply and this did not solve problem. I will be changing out main board next and post results.
Posted on Feb 23, 2008
6ya staff
SOURCE:
I have a Vizio L37. When I turn on the TV it works perfectly after about 3 minutes the screen goes to green (no picture). However I still have the sound.
My first guess would be your t-con board. The t-con board is the one that transfers teh picture from your signal board to your screen. My second guess would be the siganl board is bad.
You can get parts at www.interliquidparts.com
Nov 29, 2011 | Vizio L37 Television
My Vizio L37 keeps turning off!
change the main board will fix this problem
May 16, 2009 | Vizio L37 Television
Vizio tv
Boy, what luck! Unfortunately both those units have IR receivers that are using the same code of which you can't change, so I would put a piece of black tape over the stereo's IR window, the only draw back is you will have to turn it on manually. Try it and see if it helps and let me know.
Apr 27, 2009 | Vizio L37 Television
VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
Apr 02, 2009 | Vizio L37 Television
Vizio TV turns off as soon as you turn on the TV
Transformer is bad in the ac adapater.
Mar 22, 2009 | Vizio L37 Television
LCD controller board location on Vizio L37
Display controller is usually under the Main board which you remove to get access to it. Display controller connects to the suis-boards which then send signal to the screen of the TV.
Mar 17, 2009 | Vizio L37 Television
37inch Vizio TV making buzzing sound from back
my tv is new too and also makes a buzzing sound and i turned the DCR off and it worked to thanks for the help!!
Jan 03, 2009 | Vizio L37 Television
Tv will not turn on.
my vixio l37 will not turn on neither with the remote nor the power unit ,need some solutions
Sep 04, 2008 | Vizio L37 Television
Vizio L37
you probably changed the input mode.
Nov 10, 2007 | Vizio L37 Television
Vizio L42HDTV10A sound problems
In my case, turning the surround sound OFF is what fixed the problem. The bass contibutes most to the perception of the location of a sound. If surround is ON without surround speakers connected, the internal TV speakers can only take the place of what would be the front speakers in a surround system. So turn surround OFF and set your bass preference wherever you want it. That worked for me.
May 29, 2007 | Vizio L37 Television
Vizio L37 Television Logo
913 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
